Bass on Harmon Kardon stereo completely stopped working. Blown amp? Other ideas? |
08-29-2015, 12:09 AM | #1 |
Rep 665
Woofers/bass just disappeared. It's all treble/mids in my car now with the Harmon Kardon stereo. I'm guessing it's a blown amp? Anything else I should be checking.
08-29-2015, 03:48 AM | #2 |
Rep 2,897
I just posted the same thread three weeks ago.
The woofers will come back next time you start the car, it's weird .. Hadn't happened to me again since, probably a safe mode or some other malfunction but they do come back. |
08-29-2015, 10:01 AM | #3 |
Rep 40
Its just overheated. It does that because the bass uses the most wattage and therefore overheats the amp the most. safety cutoff. You are in Arizona and it's August in the extreme end of high temps of in the USA.
06-22-2017, 07:01 PM | #6 |
Rep 235
Any of you guys find this as a reoccurring issue? It only happened once before for me months ago and today it happened again. The problem was immediate after the car was off for 4 hours and hasnt resolved itself yet. Any service bulletins or anyone had this repaired?
06-22-2017, 07:53 PM | #7 | |
Rep 5,103
omega14587.50 |
06-22-2017, 08:50 PM | #8 |
Rep 442
Mine has done the same thing, two, maybe three times in the year I've had the car.
Edit: Nov' 2015 build date here. Last edited by orangeglim; 06-23-2017 at 04:35 PM.. Reason: added build date |
06-23-2017, 09:39 AM | #10 |
Rep 1,931
wow, never had this happen.
Im in a june build 2015, what about you guys?
www.nybmwcca.org
06-23-2017, 01:28 PM | #11 |
Rep 2,942
It's a known issue, and yes: BMW is aware. I have yet to hear about it happening on a 2017 model, which has several 'fixes' to the audio system implemented. That doesn't mean that this is among the fixes on 2017 models -- just that no one knows if it's fixed.
06-23-2017, 04:07 PM | #12 | |
Rep 5,103
omega14587.50 |
06-23-2017, 07:41 PM | #13 | |
Rep 3,888
Also sometimes the left channel doesn't work in the same manner. How do you reset iDrive while driving? There used to be a CTRL+ALT+DEL equivalent button press. |
06-23-2017, 09:31 PM | #15 | ||||
Rep 831
Hoc Lapidem Non Vi Sed Saepe Cadendo!
zenmaster1576.50 |
06-24-2017, 12:57 PM | #16 |
Rep 278
It's not related to heat. It's happened to me in 70 degree F weather car parked in the shade/garage overnight and it went out. A few others on this forum have confirmed the same. The issue is that it cannot be fixed if it can't be replicated on demand. Only work around is turning the car off, locking it and letting it sit for 5-10min.
omega14587.50 |
06-24-2017, 01:58 PM | #17 | ||
Rep 3,888
IIRC, I think it happens at start up and remains disabled until car is turned off. |
06-28-2017, 08:06 AM | #19 |
Rep 235
Anyone know a process that can be started to try and contact BMW about this being a common issue? Maybe somehow get a TSB going...I found an older TSB related to overheating AMP from 2008: http://www.m3post.com/forums/showthread.php?t=194133
07-06-2017, 11:13 AM | #20 |
Rep 39
I've never had this happen, I'm out in CA and it's been 100+ degree days. I have the front camera go out before I have my AMP go out. Perhaps there is something in your trunk area that is holding heat against it?
07-06-2017, 04:54 PM | #21 |
Rep 5,369
It's not the heat. I had this happen once and it was a 70 degree day. The bass amp was dead on start up. I turned the car off, let it go into sleep mode, restarted, and the amp was back on.
