03-05-2016, 06:26 PM | #45 | |
Rep 1,931
www.nybmwcca.org
03-06-2016, 05:28 AM | #46 | |
Rep 886
However, the issue is your definition of "minimum level" for the engine to be "warm". 140F isn't it, nor is 160F. 160F for oil temperature is the typical "stay under 3000 rpm" point you will see people quote for a turbo engine, and "don't lean on it until over 200F" is another. The fact that the vehicle info screen lets you see the oil level doesn't indicate the engine is warm. There's a reason for this. Take a crankshaft. Assume a nominal length of 18" and assume it's constructed of steel. A typical steel will have a thermal expansion coefficient of .0000073 in/(in degF). Say I roll out of my house right now (24F) and fire my car up. As I drive the engine temperature will climb to 240F. The crankshaft will grow (0.0000073*216*18 inches) = 0.028" in length. Everything fit into a bearing will grow along with the crankshaft, and all of them will increased in diameter. The bearings will grow radially, tightening the internal and external channels. Where is it at 140F? Just about half of that growth. Everything is still working to get fit together. You don't want to hit the engine hard at that point, because the critical bearings and shafts (think oil-cooled turbochargers at a couple of hundred thousand rpm) aren't close to fully seated yet.
02-12-2017, 09:23 PM | #47 | |
Rep 623
After one short use it had bent the illuminated line on top of the inside of my CD player which is killing my OCD and I'm trying to figure out if it's an easy fix of removing the unit and pushing that part back into place or if I have to try to learn not to look at it DO NOT buy one of these cd mounts, I certainly wish I hadn't Last edited by Mr Carrots; 02-12-2017 at 10:15 PM.. |
02-13-2017, 08:46 AM | #48 | |
Rep 282
2015 M4 Cabriolet DCT
2011 135i Coupe (sold) 2014 M235i (sold) 2002 M5 (sold) |
02-13-2017, 10:58 AM | #49 | |
Rep 623
Looks like the replacement cd frontplate with buttons and strip is about $80 OEM - should have just bought the proclip in the first place lol |
04-17-2017, 02:53 PM | #50 | |
Rep 23
I plan to do very similar, running an old android to get bluetooth data from a JB4 and want it semi-permanently mounted. I can't tell from the angle of the photo if your placement is making the use of the cup holders a pain or not? I don't get the car until June but doing research to buy bits ahead of time so can't measure if a phone mounted there is too low over the cup holders to prevent easy access? |
04-17-2017, 03:39 PM | #51 |
Rep 2,010
The best place for anyone's Smartphone while driving is in their pocket. I'm just speaking as someone who narrowly avoided a head-on collision last year because some bimbo was starring at her Smartphone and crossed over into my lane. If I hadn't been paying attention, we'd probably both be dead.
04-17-2017, 06:13 PM | #52 | |
Rep 116
josedebardi24.50 |
