2Addicts | BMW 2-Series forum BMW 2 Series (F22) Forum BMW 2 Series Coupe and Cabriolet (F22/F23) General Forum Spark plug check
      09-20-2020, 04:14 PM   #1
JoelEnc
Drives: 2015 BMW M235i Xdrive
Spark plug check
I was having an issue with my car saying it was running lean. Prior to this I had a boost leak that was making my car run rich then I had my boost leak fixed. The lean code eventually went away but sometimes at idle my car will have some weird hiccup where it seems like a misfire, but I don't receive any misfire code so I was thinking maybe a bad spark plug? I pulled my spark plugs out to see if they were bad. They are the 97506 ngk gapped at .022 with only 6k miles on it. Can anyone tell me if they are in need of replacement or if anyone can diagnose what my problem may be?
      09-20-2020, 04:52 PM   #2
Lucky13
Lucky13
Drives: 2014 M235 manual, 2020 X3 30X
Ignition coil?
1995 325i, 1996 328ci, 1997 528i, 1997 Z3 2.8, 2000 528i, 2001 X5 3.0, 2001 330i Convertible, 2002 M3 Convertible, 2003 M3 Coupe, 2004 M3 Coupe, 2004 Z4 3.0, 2004 X3 3.0, 2007 X3 3.0, 2007 335i Convertible, 2013 X1 28 sdrive, 2014 M235 manual, 2020 X3 30i Xdrive
      09-20-2020, 04:54 PM   #3
JoelEnc
Originally Posted by Lucky13 View Post
Ignition coil?
I also put brand new coils with my spark plugs maybe their defective? But on the other hand do the spark plugs look okay?
      09-21-2020, 05:50 PM   #4
MarcoZandrini
Drives: 2018 M240i
The plug looks fine.
      09-21-2020, 06:05 PM   #5
overcoil
Drives: M235i 6spd
where did u purchase your plugs and coils from ? dealer or Amazon.
      09-21-2020, 06:09 PM   #6
JoelEnc
Ecs tuning
      09-21-2020, 06:26 PM   #7
overcoil
Drives: M235i 6spd
Originally Posted by JoelEnc View Post
Ecs tuning
I was gonna say counterfeit auto parts from Amazon. But ECS seems like a smart choice.
      09-21-2020, 09:34 PM   #8
mikeysosa
mikeysosa's Avatar
Drives: 2016 BMW M235i
1995 Mazda Miata  [0.00]
2016 BMW M235i  [0.00]
Maybe try switching back to OEM plugs and see if that resolves the issue. Also, try not to run extra boost if you are and see if it goes away.
      09-21-2020, 10:10 PM   #9
XutvJet
These cars are very picky about plugs. I've also noted a lot of people reporting misfires and issues when running smaller plug gaps.
What power mods do you have?
      09-26-2020, 10:07 AM   #10
JoelEnc
I am fbo but I'm running a stock intake and the spark plug gap I have on my ngk plugs is .022. I have the stage 2 93 octane tune from bootmod3.
      09-26-2020, 03:48 PM   #11
Unicorn123
Drives: 2016 M235i xDrive
May be carbon...?
OP,
I just had my plugs replaced with OEM @ 77K miles. I was late in doing this maintenance and had the plugs but no time; my local trusted indie put them in for me while was away on travel last week along while performing a full fluid replacement on my car, which I had scheduled.
After replacing my plugs, the mechanic noted a #3 cylinder miss-fire and called me to ask if the car was missing and throwing a code prior to drop-off, which it was not.
Swapping the plugs with the old ones, different ones and the ones I purchased did nothing.
It turned out the #3 fuel injector was encased in carbon build-up and he had to do a full intake cleaning to clear the codes and clean up the fuel injectors. He saw a similar situation on a M235 with 30K (miles) on it that he serviced about 6 months ago.
You may want to check to see what kind of carbon buildup you have, this is not uncommon with direct injection engines like the N55 and B58; this may explain the issues you are seeing. Good luck.
Current Fleet, 16 F22 M235i xDrive, 15 Audi Q5 3.0 TDI (my Wife's), 07 E85 Z4M Roadster, 01 Toyota Tundra 2wd Long Bed
Retired (a few of them...), 08 E60 550i 6M, 01 Audi S4, 70 Fiat 124, 88 E28 M5, 72 Datsun 510 2Dr, 73 TR6
dradernh4414.50
