2Addicts | BMW 2-Series forum Technical Topics Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics The "Official" F22 OBD2 wireless adapter / Android+Torque / iPhone+DashCommand thread
      03-14-2016, 04:33 AM   #155
Zooks527
Originally Posted by simoneves View Post
I use an Automatic, and it has a code printed on the side which I had to enter when registering it with their own app, and I'm pretty sure I had to use that login to register it with DashCommand too. Does that qualify as "closed"...?
I can't speak to that model, but the real question is if anything special was required to pair it to your phone as opposed to the companion app.
All of the ones I have seen (far from a long list) use either 4 or 5 digits to pair to the phone, with the PIN being either all zeros, all ones, or a straight sequence starting at one. Something other than that is a good start, but that's all it is - a start.
      03-14-2016, 06:11 AM   #156
BentZero
BentZero's Avatar
What I want to know is if anyone has had anything bad happen to them because of the open access to their ECU.
      03-14-2016, 07:17 AM   #157
Zooks527
No idea. I'd assume the probability is currently very low due to the limited number of users. The utilization density is likely not great enough to attract much attention. This would certainly vary based on where you live / work (out in the sticks versus downtown).
Still, what is currently a low probability is going to grow. Low-density defense is why so few Mac computers had virus issues - it was more productive to go after the greater number of PCs. That's changing, however, and people who developed the habit of thinking "It's a Mac, so I don't worry" are now getting bit.
      03-15-2016, 06:44 PM   #158
scottomfg
scottomfg's Avatar
287
Drives: '14 Cayman S 6MT, '21 X5 45E
You might be able to pair with the Automatic dongle w/o using the app, but the data would be useless. It uses a proprietary data protocol over an encrypted bluetooth connection, not the standard OBDII protocol. It seems like this would essentially make it secure, yes?
BTW, I use the Automatic dongle with DashCommand on OS X and it works great, love it. Very useful for making sure the engine is fully warmed up before I get into some shenanigans.
2014 981 Cayman S 6MT, X73 Suspension, SES
2021 X5 45e MSport, Manhattan Green, Coffee Merino, Review & Photos
Previous: '18 340 GT, '15 M235i 6MT, '15 i3 REx, '15 x1 xDrive28i
      03-15-2016, 07:29 PM   #159
Zooks527
Better than nothing, but not really "secure". Anyone who wanted to spend the time dealing with the entry code to access the data should be able to reverse engineer the software.
Realistically, the first level of security should be a hardware means of setting the adapter into broadcast mode, rather than having them open to anyone who tries. Hell, even a BT mouse has that.
      03-15-2016, 07:30 PM   #160
scottomfg
scottomfg's Avatar
287
But the data is encrypted. You can't reverse engineer software to get the encryption key.
      03-16-2016, 04:12 AM   #161
Zooks527
Typically, the encryption key is negotiated as part of the pairing. I'd assume the path of attack would be to reverse engineer the software linking routine to negotiate your own encryption key when you connect. An attack doesn't want to listen to the datastream while the adapter is connected to your phone, it wants to negotiate its own link.
Again, low probability event, as many of the BT OBD plugs don't do any of it at all, so it's easier to go after the low hanging fruit before chasing a unit with a custom security scheme. And since I haven't spent any time looking at the Automatic adapter, it's implementation of security might be far higher than I am assuming. Still, if there isn't a hardware "pair now" button, the dongle is vulnerable to a brute force attack on the pairing PIN. Pushes it to an even lower probability - first you need to be found by an attacker looking for that type of adapter, then the attacker needs enough time to brute force a large number of codes, all while the adapter remains active on the ECU.
      03-16-2016, 06:02 AM   #162
BentZero
BentZero's Avatar
What could some nefarious criminals do once they gained access?
Build thread
      03-16-2016, 09:01 AM   #163
Zooks527
You can code the car through a wireless OBD port. Think of anything you see people talking about coding their car to do (there's a long thread on what you can do with F-series coding) and do that. Or, someone could disable the car just because he can.
Here's a mildly amusing example of what you can do with poorly thought out access systems: http://mjg59.dreamwidth.org/40505.html
Again, low probability. Still, isn't zero. To my knowledge, there hasn't been a car theft on my street in the 30 years we've lived there. Doesn't mean I'm going to start leaving my car unlocked in the driveway with the fob in the cupholder.
      03-16-2016, 09:47 AM   #164
BentZero
BentZero's Avatar
Ah, I see. That makes sense. If only the iSaddle had a POPO toggle switch on the outside of the unit. That way I could keep it plugged in at all times and just toggle it off and on as needed. Maybe I'll contact them or take the unit apart and see if I can fabricate one myself.
Build thread
      03-20-2016, 11:51 AM   #165
BentZero
BentZero's Avatar
Well, I took apart the iSaddle to see where I could add the switch and then decided that I'd have to remove solder to really get to where I wanted to get. Anyway, I found a dongle that has a built-in power switch already. It'll be awhile until it gets here though, so for the time being I'll continue to either not care about it being plugged up or unplug it. Just depends on where I am.
In the long run I'm going to search for a more integrated solution. It'll probably be one of the last things I do though as I don't really mind the current setup too much.
I'll post an update when the new unit comes in.
Build thread
      03-31-2016, 11:35 PM   #166
BentZero
BentZero's Avatar
Got the new unit in today from Amazon. The on/off switch works like a champ. Took a bit more trial and error to get it connected to my phone. Once I did oil temps worked, so I'm happy. Not as plug and forget as the scan tool model, but i'm happy with this for now.
http://www.amazon.com/Elm327-Bluetoo...ilpage_o00_s00
***Update***
Well, that thing was a bust. It worked for a few days, but now I'm having connection issues. Sometimes Torque just doesn't see it unless I bounce Bluetooth on the phone or toggle the device off and on which is a bit of an annoyance when you're driving. Going back to iSaddle.
Interesting note about the iSaddle. When the vehicle is off no data is transmitted to it. Not sure if this means that it's an auto shut-off feature of the dongle or if that's just how the vehicle operates. Idk. Just an added detail for those that are concerned about leaving the dongle plugged in all of the time. I do know that I want something more integrated than a phone mounted to the vent at some point. Knowing your oil temps is pretty crucial and I can no longer live without it lol.
Build thread
      06-17-2016, 09:29 AM   #167
barfastic
Greece
37
Drives: 228i M Sport Pack
Has anyone tried "ScanTool 427201 OBDLink LX Bluetooth" out? I didnt provide a link as i am unsure if i should, but a quick search on amazon should yield you the result.
It looks decent, even though it is higher priced than most out there.
M
      07-16-2016, 08:42 PM   #168
omasou
omasou's Avatar
Drives: BMWs
2023 BMW S1000RR  [0.50]
2022 BMW F900XR  [3.00]
2022 BMW X6 40i  [0.50]
2020 BMW M2C  [9.50]
Originally Posted by Monoblock View Post
I started posting about my use of OBD2 wireless adapter in 4 other threads, and realized the info is now scattered about and hard to find. I thought I'd try to consolidate things.
Also, since it's known that there are dodgy OBD2 adapters out there, this thread might serve as a place for people to post their experience with specific adapters over time - whether they work or not, durability, best price for value, etc ...
Doe the BMW M Performance Drive Analyzer work with any ODBII WiFi adapter like those listed or only w/the BMW one?
      08-06-2016, 02:55 PM   #169
EBM235
This question was asked earlier in the thread, but don't think it was answered. Does anyone know how reliable the data is in regards to HP and torque? I have input the details of the car in hopes that it is somewhat accurate, but just want to check if anyone had confirmed. TIA
      08-16-2016, 05:44 PM   #170
Sypher
Drives: '16 228i xdrive
Is there a way to code the car such that the 12v socket turns off immediately or at least shorter than the default time it takes for the socket to turn off? I have a phone that I leave in the pocket in front of the cup holders constantly plugged in right now that is set to go into airplane mode and display off when no power is detected. Problem is, which the car is off but power is still on, the phone stays awake and you can see the screen on from outside the car. I want to minimize that as much as possible.
      12-05-2016, 09:17 PM   #171
jpnh
jpnh's Avatar
1425
Drives: NA
OBDLink MX on order.....
      12-17-2016, 07:14 AM   #172
horsepower_and_hounds
Drives: BMW
Anybody done this set up with a Kindle Fire or similar tablet? If so how do you go about mounting it in the car without blocking all your other items.....
      12-17-2016, 07:32 AM   #173
jpnh
jpnh's Avatar
1425
Drives: NA
There's no "GOOD" place to put something that large and still have it reasonably within line of sight
Something small like an iphone 4s will fit in a lot of spots...
I personally only "need" temperature functions on a regular basis so......
      12-17-2016, 09:22 AM   #174
Drives: BMW
Yea just an idea.....I grabbed a clean HTC Vivid off of e-bay to play around, it is pretty small and thinking about that Belkin cup holder mount and not really block any of the controls or vents. I wanted to use reliable bluetooth connection instead of wifi and my iPhone 7+
      12-17-2016, 09:38 AM   #175
jpnh
jpnh's Avatar
1425
Drives: NA
I struggled with the same issue and ended up going with the
OBDLink MX Wi-Fi because it allowed me to use Wireless with iphone because of built in WPA2 with AES encryption
Personally I feel its a better/more secure option than bluetooth...ymmv
I was also looking at the Samsung Galaxy Tab A 7" which isnt THAT much bigger than an iPhone 6/7
The Tab A 7 is 7.36 x 4.28 x 0.34 in
The iPhone 6 is 5.44 inx 2.64 in x 0.27 in
For ~100 bucks it might be worth the experiment
      12-17-2016, 10:39 AM   #176
Drives: BMW
The Kindle is 7.5 x 4.5, my iPhone 7+ is 6.5 x 3.25. The HTC Vivid is 5 x 2.6 and I paid 35 bucks for it
