2Addicts | BMW 2-Series forum Technical Topics Cosmetic and Lighting Modifications IND Painted Reflector Installation Procedure
      01-18-2016, 07:38 PM   #89
neilr_
Drives: 2021 X3 M40i Phytonic Blue
Originally Posted by BEM-S4 View Post
It's easier when the plastic is warm and more flexible.
I know a setup when I see one. ;-)
      01-19-2016, 10:27 AM   #90
BEM-S4
BEM-S4's Avatar
Ha unlike my advice of "pull and pray" for interior trim removal I wasn't trying to make a joke here!
      01-19-2016, 12:26 PM   #91
HandsomeDevil
F22 Pilot
14
Drives: m235i 6MT
Originally Posted by BMWZ4 View Post
I broke the clips for both sides, but they were headed to the bin anyway. New ones going in...no danger snapping anything off. They go in super easy.
As for the park sensors...I have the sensors and you just have to pull the plastic wheel well further out (you won't snap anything) to get at it. Took a few extra minutes. No gloves.
if I can save mine I will otherwise I won't lose any sleep if they're destroyed, as long as it's not anything on the car itself.
Originally Posted by neilr_ View Post
I think it took me more than an hour to get both sides installed and I broke one of the clips on the second reflector. I found that one of the clips (the bottom one, maybe?) was easy to reach and relatively easy to unclip. The other clip was behind something that felt like a plastic block, which made unclipping difficult, thus the broken clip.
This is a project that I would have saved for spring (frozen fingers are nearly useless) except that I had an Xpel appointment and I wanted the reflectors covered.
yeah spring would make more sense but I'm going to do it now as I rather not wait.
      02-28-2016, 05:43 PM   #92
HandsomeDevil
F22 Pilot
14
Drives: m235i 6MT
I finally got around to installing these and it was painful at first until I tried with pliers. The first one took about 30m because I was being super careful but the 2nd one was about 5m lol. I actually chipped the paint somehow, not sure how exactly because nothing snapped off but oh well... it looks great. I'll just get the paint chip taken care of before xpel treatment.
      03-10-2016, 01:20 PM   #93
omega145
omega145's Avatar
88
Drives: 2016 M235 Xdrive
Good writeup but the clips are a lot tougher than it looks. Took me about 2 hours in total to do front and rear reflectors along with the lock cover. Broke both clips on front reflectors and completely destroyed 1 rear reflector. Not to mention my thumbs are still sore from doing this 4 days ago. Definitely a worthwhile upgrade and product but don't expect it to be as easy.
      03-14-2016, 08:50 PM   #94
bizfiend
bizfiend's Avatar
Drives: Renting Corolla lol
Looks good just need to lose the orange bulb now... Then we'll be twins.
what color did you change it.
what size is it.
is it difficult to install yourself, how.
Thanks.
      03-17-2016, 08:19 AM   #95
BEM-S4
BEM-S4's Avatar
what size is it.
Thanks.
Chrome when off orange if on.
Bimmian sells it do not get the 180 you need 150 if memory serves (location of bumps on plug end).
Check owners manual for instructions.
Do not touch bulb with bare hand, oil can create a focused hot spot and cause failure.
      03-17-2016, 11:09 AM   #96
Anthony235
Anthony235's Avatar
Drives: m235i
2015 BMW  [0.00]
Used a dash trim tool. Took about 15 minutes and some broken OEM clips.
Just assume you will break the OEM reflector clips...
Angled needle nose pliers would help if you have them.
      04-28-2016, 11:21 AM   #97
haOo
Drives: Black 228i
Sorry to bring up a semi old thread but I've been trying to research but havent come to anything conclusive. Will these fit a 2016 base coupe 228i?
      04-28-2016, 12:29 PM   #98
pikcachu
pikcachu's Avatar
1406
Drives: M235i (F22 Red angel)
should fit any 2 series
      04-28-2016, 12:51 PM   #99
haOo
Drives: Black 228i
thanks for your quick reply!
      05-06-2016, 06:28 PM   #100
ArcticCave
Drives: Alpine White 228i
The painted reflectors for a base 228i is not the same as the ones for a m-sport or a m235i!. Don't order the wrong one or you will waste a lot of your time. I don't think they have the one you need on IND yet. I just messaged Ryan@IND and he custom ordered the correct part number for me.
Here is a picture of my base 228i with painted reflectors.
      05-08-2016, 09:33 PM   #101
haOo
Drives: Black 228i
LOL I found out the hard way you replied a little late but thank you though! As a matter of fact i ordered from Ryan the day before your post. Thanks again
      05-09-2016, 10:53 AM   #102
leeadam
leeadam's Avatar
United Kingdom
469
so glad we dont have to do this in the uk
      05-18-2016, 03:52 PM   #103
wdlfbio
Drives: 2013 4S, 2015 3500 HD Dually,
Anyone consider drilling them out from front to rear? Start with a small bit and get larger? With the new clips in hand, it should be easy to trace a template of where the clips are , then transfer that to the reflectors. Start drilling...
'16 235i
'15 3500 HD Dually
'13 C4S
      05-18-2016, 05:07 PM   #104
Anthony235
Anthony235's Avatar
Drives: m235i
2015 BMW  [0.00]
What?
      05-18-2016, 06:46 PM   #105
mdputnam
mdputnam's Avatar
289
Honey, I think I got the reflector off!
Appreciate 5
Poochie9107.50
      05-20-2016, 02:07 PM   #106
puffalo
puffalo's Avatar
Drives: M235 Coupe 6MT RWD
Another beauty of an upgrade. Thank you Ryan for the installation tutorial. The Install was very smooth, all four done in under 30 minutes
      06-07-2016, 11:01 PM   #107
bmw235iSD
Drives: 235i
View post on imgur.com
Very easy! broke 1 tab but don't really care, other came off fine. Was very easy and quick.
      06-08-2016, 12:42 AM   #108
siwo
siwo's Avatar
Drives: 2016 M235i RWD 6MT
I really like this look, but then I'm not sure if I want to remove the reflector even though it doesn't seem like it serves a purpose! Damn, so indecisive.
2015 ES350 6AT - Traded In
2004 RX330 5AT - Sold
2004 Civic Coupe Si(EX) 5MT - Retired
1993 Civic Coupe Si(EX) 5MT - Retired
      04-28-2017, 04:50 PM   #109
K9GunSlinger
Drives: 2016 M2 MG 6-Spd
is that Mineral white or alpine white? if mineral..hows the color match of the painted reflectors? thanks!
      06-06-2017, 09:11 AM   #110
Bixby
Drives: M240
I can't find a rear reflector install guide. Is it pretty easy/self-explanatory?
