02-18-2016, 06:59 PM | #89 | |
Rep 444
I highly doubt you will rub with a 265/30/19x9.5 ET44. I have more than 4mm space between my tires and the strut guard. If for some reason you need to, you can cut the plastic housing. Someone here has already done it. It will free up a lot of space. On the front, the 40 will most likely rub the suspension while the 30 will probably hit your fenders. If you roll your fenders you might be able to get away with 30s, but just guessing. The 40s with 3-5mm spacer would probably be ideal.
Quickest Stock Turbo F8x In The World
02-18-2016, 09:14 PM | #91 | |
Rep 1,184
Ahhhh you guys are the worst/best. I was saving for a fmic and enzo tune....but I can't pass up this deal now. Looks like I'll just have to work harder and get all 3 |
02-18-2016, 11:29 PM | #92 | |
General
2052
Rep 25,988
VMR|Wheels | 714.442.7916 |
02-19-2016, 05:02 AM | #93 | |
Rep 1,184
02-20-2016, 06:26 PM | #94 | |
Rep 444
I got the FMIC and Enzo tune before my wheels and I would probably do the same again. The Enzo tune transforms the car. The single best mod for the M235i in my opinion.
02-21-2016, 02:17 PM | #96 | ||
Rep 893
So it sounds like 235/35/19 on square 8.5" 40et wheels should fit fine?
2019 SG M5C
02-22-2016, 03:32 PM | #98 |
Rep 1,184
I think I am going for it guys. I got someone interested in my current wheels so if that goes through I am going to order
HRE Flowform F15s 19x8.5 et40 + 5mm spacer and 19x9.5 et42 Ill get the tires when its a little warmer out but I am going to try the 235/265 combo! Thanks for the help everyone hopefully everything comes together and I get a working set soon |
02-23-2016, 09:03 AM | #99 | |
Rep 167
However, Im lowered on HR Springs though so a little worried. I am willing to roll fenders and run some camber if needed. Will probably stick with 255 in the rear however. |
02-23-2016, 11:33 AM | #100 | |
Rep 647
I thought they only offered a 19x9 ET44... |
02-23-2016, 11:42 AM | #101 |
Rep 1,184
02-23-2016, 11:44 AM | #102 | |
Rep 1,184
I'd like to do the Dinan drop and M4 LCA at some point. I wonder how that would work out. Also if 265s rub for some weird reason I'd prob sell and go 255. Would adding negative camber help or hurt this fitment? Anyone know? |
02-23-2016, 12:04 PM | #103 |
Rep 647
Ok, yea just got off the phone with HRE. That's great that they offer that fitment seems like that offset will be right in the ballpark for squeezing a 265 in. Good catch JM..!! I am also going to be on Dinan springs w/ supplemental ride kit. Hoping to fit a 265 as well... I just wonder weather it would be smarter to go ET44 on 9 with and spacer to make perfect or go straight to ET42 and 9.5. Will a 255 be safe on a 9.5 ET42 w/Dinan drop..?
02-23-2016, 12:16 PM | #104 |
Rep 5,262
The LCA will move at the same time as the strut so there is no difference on the inside of the wheel but it should help on the fender side as it will tuck to top in a bit... although the LCA moves the whole wheel about 1 inch further forward
02-23-2016, 02:48 PM | #105 |
Rep 1,184
Interesting. Do you know if that 1" forward makes it any tighter or not?
02-23-2016, 02:56 PM | #106 | |
Rep 1,184
19x9 255 works? Stretch/poke/flush 19x9 265. Works? Stretch/poke/flush? 19x9.5 255 Works? Stretch/poke/flush? 19x9.5 265 Works? Stretch/poke/flush? |
02-23-2016, 03:04 PM | #107 | |
Rep 1,084
it was necessary for me to increase offsets (et35->et40) to avoid fender liner interference once I installed the LCAs |
02-23-2016, 04:29 PM | #108 | |
Rep 5,262
02-23-2016, 08:40 PM | #109 | ||
Rep 2,494
02-23-2016, 08:53 PM | #110 |
Rep 1,184
