12-08-2022, 07:58 AM | #8933 | ||
The Seeker
14193
Rep 3,426
The lower the TW, the worse it is, so yes for sure. Quote:
Tire tech is wacky really. |
12-08-2022, 07:54 PM | #8934 |
Rep 1,333
Installed the custom corner bracket today? Fit perfectly!
12-09-2022, 10:58 PM | #8935 |
Rep 507
Drives: 2018 M2 6MT
Got her up in the air for some refreshing new fluids: engine oil and diff oil. I’m assuming this was the car’s first diff fluid change — at 33,685 miles — those diff drain and fill plugs were on tight!
///M TOWN22356.50 IcewaterPete2226.50 |
12-10-2022, 01:51 AM | #8936 |
New BMW owner
328
Rep 846
how was the condition of the DIFF fluid?
2018 BMW M2 LCI BM3 Stage 2 + MPE + FTP charge pipe + MST V2 Inlet + TurboSmart DV + CSF FMIC + AA Hi-flow Downpipe + Turner Rear Shifter Bushing + Wiechers Strut Brace + Bilstein B16 PSS10 + Apex VS-5RS
12-10-2022, 09:43 AM | #8937 |
Rep 406
Drives: BMW 328xi BMW X5 F15 BMW M2
I installed the Precision Raceworks coil packs last week and the first thing I noticed is that the car has a deeper tone. There’s definitely a few high pitch decibels lost from the engine which I like. Another thing is upshift burps from 1st-2nd-3rd gear manual shifting in sports mode. The idle is spot on and the revs are smooth and throaty in a way.
Stylin.M2302.50 DrKevM52281.00 ///M TOWN22356.50 cbmmm3318.50 FlashmanM23.00 Al Bundy's Dodge1680.00 JMM125.50 Altra267.00 |
12-10-2022, 11:33 AM | #8938 | |
The Seeker
14193
Rep 3,426
12-10-2022, 11:52 AM | #8939 |
Rep 85
CSF Intercooler
FTP charge and boost pipe Turbo smart DV MST turbo inlet Turner poly shifter bushing BM3 That woke her up a bit!
2018 BMW AW M2
ShortSides413.50 ///MPhatic14193.00 ///M TOWN22356.50 Stylin.M2302.50 dtmurf486.00 CamaRai27.00 BoltacoreMD3.00 JMM125.50 aatlas214.50 Drifter2090913.50 |
12-10-2022, 12:09 PM | #8940 |
Rep 507
Drives: 2018 M2 6MT
The diff fluid was medium-dark brown in color. It was a very uniform consistency: sorta like thick mucous. There was a very slight shimmery quality to it. And it smelled pretty bad. Though I was warned about the smell, so I was prepared for worse and it didn't end up smelling as bad as I'd feared.
After letting the diff drain for 30–45 minutes, it was down to a drip every 10 seconds or so. That's when I put in the new drain plug and refilled. It ended up taking about 1 ⅓ qts of new SAF-XJ fluid. |
///M TOWN22356.50 ///MPhatic14193.00 |
12-11-2022, 09:50 AM | #8943 |
Rep 85
Right! Definitely not the most fun time I have had..
2018 BMW AW M2
12-11-2022, 03:17 PM | #8944 |
your average JAMF
3196
Rep 4,116
Drives: '21 M2 Comp, '19 Golf R
Diff fluid would have been changed at the 1200-mile break-in service. Did the original owner skip it?
'21 M2 Comp
'19 Golf R |
jefe2000785.00 |
12-11-2022, 03:22 PM | #8945 |
Rep 507
Drives: 2018 M2 6MT
I don’t have the service records from the original owner. It had been taken in for service by the original owner exclusively to a southern CA BMW dealership. I talked with the Service Manager at that dealer’s service department — prior to me purchasing the car — and he indicated all expected services had been completed on time. So good point: the diff fluid was likely already changed once before.
///M TOWN22356.50 |
12-12-2022, 12:06 PM | #8946 | |
22357
Rep 8,738
jefe2000785.00 |
12-12-2022, 12:15 PM | #8947 |
your average JAMF
3196
Rep 4,116
It's possible that the service was reported to CarFax if it was done. Try this: Set up a free MyCarfax.com account, plug in your VIN - any/all service records that were reported will show up. If it's there, it would be good to have documentation of it having been completed. You could even try to going to the named dealership and getting a copy of the receipt.
'21 M2 Comp
'19 Golf R |
jefe2000785.00 |
12-13-2022, 10:24 PM | #8948 |
Rep 446
Drives: 2018 M2
All weathers in today. Winter wheels sometime this week. Finally getting extra cold here in KC!
Current: 2018 M2 DCT
Previous: 2011 E92 M3, 2007 E92 328xi Insta: @kmannc |
Stylin.M2302.50 |
12-14-2022, 08:23 PM | #8949 |
Rep 507
Drives: 2018 M2 6MT
I didn’t find any of the prior service history for the car on CarFax. However I found that the prior service history items do show up on the AutoCheck (a competitor to CarFax) report. And since the service items were all done at a BMW dealership, I might ask the local service department if they can give me a printout of the service history.
12-16-2022, 01:50 AM | #8950 |
22357
Rep 8,738
I fired her up, backed her out, warmed her up, and pulled her back into the garage….
And I made sure that my heater was still working properly Good Lord it’s cold out 🥶
12-16-2022, 03:05 PM | #8952 |
22357
Rep 8,738
Stylin.M2302.50 WagonMaverick400.00 chris7197393.50 iam2slow78.50 Humdizzle6139.50 D22M21373.50 shaneguags1197.50 cbmmm3318.50 eldogo275.00 |
12-17-2022, 03:33 AM | #8953 |
Rep 17
Drives: 2018 BMW M2
New M Performance wheel for my 2018 M2 LCI
12-19-2022, 10:10 AM | #8954 |
Rep 446
Drives: 2018 M2
Silver 437m with Michelin pa4 for winter
///M TOWN22356.50 jefe2000785.00 JMM125.50 dtmurf486.00 vrooooom327.50 ///MPhatic14193.00 cbmmm3318.50 IcewaterPete2226.50 VicF87OG72.50 |
