07-15-2021, 06:49 PM | #67 | |
22348
Rep 8,738
Both are stock and both have DCT The OG is easier to launch
07-15-2021, 07:28 PM | #68 | |
Rep 604
07-15-2021, 08:51 PM | #69 | ||
22348
Rep 8,738
Highway speeds is where the S55 shines OG M2 is amazingly quick from a dig
07-15-2021, 09:35 PM | #70 | |
Rep 7,542
In regards to what's a better track car it's the og m2 the only feature that matters is the sump, the b58 doesn't have any baffling, scavenge pumps, or additional pick ups (like the s58 which allows it to have guaranteed oiling up to 1.3G). So the m240i will likely have oil pressure issues on track leading to rod bearing failure. There are other things too like the OG m2 has better sub frames, alot of aluminum suspension components. So if you start to mod the two cars I feel the OG m2 has a better starting point with a higher track potential. The b58 may be better cooled so maybe it'll have a higher power potential but the chassis isn't as good. Overall out of the box the m240i might have similar if not better lap times than the OG simply because it has alot more power and the G series seems to be able to put power down alot better than the F series. But other than that as stated above the OG m2 still has alot better features in it's sump, sub frame, and suspension. I also feel the OG m2 is too stiff in the rear which allows it to be playful but it doesn't allow it to have enough mechanical grip. It also has a but if body roll which seems to throw of it's grip in rapid slaloms. So right off the bat I feel there is a lot of time to be had if the suspension was softer and the sway bars were stiffened to help with body roll.
Robimplicit16.00 |
07-15-2021, 09:49 PM | #71 |
Rep 6,607
07-15-2021, 11:10 PM | #72 |
Rep 1,675
07-15-2021, 11:12 PM | #73 |
Rep 1,675
07-15-2021, 11:21 PM | #74 |
Rep 7,542
I saw on a car article that the Xdrive version with the auto is in the 4100 lbs range, which is fricken insane. Not sure if these numbers are legit but if they are that thing is a tub of lard, and you will definitely feel it in the corners.
///M TOWN22347.50 |
07-15-2021, 11:45 PM | #75 | |
22348
Rep 8,738
He's talking about the G82 I have no idea why but that's fine Moving right along
07-16-2021, 01:54 AM | #76 |
S0THPAW
8784
Rep 7,853
07-16-2021, 02:41 AM | #77 | |
22348
Rep 8,738
Porky 🐷
07-16-2021, 03:14 AM | #78 |
Rep 7,542
Yeah not a good look for bmw. I thought the F series was getting heavy (M2 was a coupler of hundred of pounds heavier than the 1m) and was not happy with it and yet bmw is still making these things get heavier and heavier.
///M TOWN22347.50 |
07-16-2021, 03:44 AM | #79 |
enthusiasm > practicality
4027
Rep 2,247
Drives: 987 CS | G35x
If true, 400+ lbs porkier than the '16-'18 M2. It's evident that BMW simply doesn't give a shit about controlling weight anymore. Them and the majority of Americans are on the same wavelength in this regard.
FSI 3.8L Stg II|6MT|SOUL|IPD+GT3 TB|Numeric Racing|KW|Tarett|Rennline|Raceseng|APEX|Recaro|7.3 lb/hp
VQ35HR|5AT|Stillen|FI|UpRev tune 8k rpm|TransGo|Hotchkis|Whiteline|H&R|Z1|Corbeau|R1 Concepts|10 lb/hp Left lane campers, GTFO! |
///M TOWN22347.50 |
07-16-2021, 05:16 AM | #80 |
Rep 6,638
07-16-2021, 06:38 AM | #81 |
Rep 8,679
I think people tend to forget how strong BMWs base offerings are these days... this isn't 2002 where we had a monstrous E46 M vs a lolable 330i.
It's 2021 where we have a very potent M340i and an even more potent G80 M3. The baseline car is more than enough car for most people... The M2 will feel rawer, more connected and offer a better driving experience but as a car, the new M240i will probably be faster, could do at least 1 lap quicker, will be more comfortable and have newer tech. For most people, outside of the hardcore few, that will be more than good enough. IMHO, BMW really shoots themselves in the foot where they make the non m models in the succeeding generation faster than the prior M... something seems very offputting about that.
2 x N54 -> 1 x N55 -> 1 x S55-> 1 x B58
07-16-2021, 07:04 AM | #82 | |
Rep 6,638
07-16-2021, 07:23 AM | #83 | |
Rep 8,679
https://f87.bimmerpost.com/forums/sh...89&postcount=1 The M2 OG does indeed have an advantage in the 1st 2k of the rpm range likely due to a far smaller turbo... but it ends there and in a large way.
07-16-2021, 08:08 AM | #84 |
Rep 4,145
Drives: '18 M2 6MT
07-16-2021, 09:15 AM | #85 | |
Rep 1,675
///M TOWN22347.50 |
07-16-2021, 10:18 AM | #86 |
Rep 8,679
I mean if you're referring to like valet mode racing... i.e. up to 2k rpm sure... but I think an I3 would blow both of us away there... perhaps a nissan leaf as well.
07-16-2021, 12:01 PM | #87 | |
22348
Rep 8,738
That's a lot of weight for a smaller coupe
07-16-2021, 12:12 PM | #88 | |
Rep 77
