10-13-2021, 01:28 PM | #67 |
Rep 5,393
Yank everything and return to stock and put the car on a trickle charger.
I can not stress how touchy German electronics are. BMWs are not Subarus, Hondas, or a GM product. They have a number of computers and systems constantly talking to one another, even when the car is off. For an of example extreme BMW integration, when the wipers are on and you're in Sport mode (Sport throttle setting), the stability control nannies are hyperactive with respect moderate or heavy throttle tip-in as well as wastegate operation. Why? Because the DME assumes that if the wipers are on, it's slick out so the DME adjusts throttle input and boost to keep the tires from spinning if you stab the throttle too hard at first. You're not seeing that in a more standard car.
nazali1334.50 |
10-13-2021, 01:56 PM | #69 |
Rep 1,146
I mean I get stuff for the car, but I've ONLY put on BMW OEM DEALER only parts, for this very reason, I mean except the dashcam, not sure if BMW do a dashcam
10-13-2021, 02:01 PM | #70 |
Rep 1,146
10-13-2021, 02:04 PM | #72 |
Rep 1,146
Driving and surveillance camera front+rear, Basis kit - original BMW Advanced Car Eye 2.0
66212457032 66 21 2 457 032 2457032 Product number: 66-21-2-457-032 407.65 USD excl. vat (from a vendor) God knows how much BMW charge for it including fitting |
10-13-2021, 02:05 PM | #73 |
Rep 1,146
considering there's "nothing wrong" at all with my car and I yet I can't not drive it, without it comitting suicide ,
I doubt I'll be sinking any money in to this odious vehicle (Odious is my word for the day, woo hoo I managed to use it in a sentence) |
10-13-2021, 04:23 PM | #74 |
Rep 1,146
Got car back, got home wanted to test the keyfob.
The keyfob can do the alarm, from some serious distance, from car parked on drive to garage door is about 20ft, from there to the front door another 20ft. from there to inside the house say 20ft, from there to the back door 20ft, I also trie upstairs in my bedroom to the back of the house, I also tried in the basement I can open my car door, easily, 80ft, is this fooking normal ? Forget comfort acces or start , the car alarm can be activated that far The key is being detected from as far away as 80-90ft. I'm going to go out and pace to the top of my road and check again Can anyone out there tell me the furthest you can get |
10-13-2021, 04:38 PM | #75 |
Rep 1,146
home made faraday cage, one layer of tinfoil on the spare key, can't alarm or disarm
wonder if that was causing the problem ? 2 keys transmitting or being aware of the car ? don't know how it works ? still putting the car on charge tonight, I can't risk not getting to work tommorow |
10-13-2021, 05:15 PM | #76 | |
Rep 5,393
10-13-2021, 05:36 PM | #77 |
Rep 1,146
10-14-2021, 01:26 PM | #78 |
Rep 1,220
Drives: 2015 M235ix
Why did it take all this back-and-forth to learn that a dashcam had been installed?
OP: get back to us once you have completely uninstalled it and let us know if it was the culprit. |
nazali1334.50 |
10-14-2021, 04:31 PM | #79 |
Rep 1,146
I've had a lot of threads, and I did say I had a dashcam, and this one wasn't about that initially, hence why I did not mention it unless asked much later.
The dash cam I had in the car since I had it and was fine for 2 months, as said I changed the settings which killed the battery. There's 4 pages on this thread so I guess things get lost, dash cam is no longer connected but the wiring is. Yesterday I had car on charge overnight and put keys in foil (faraday cage) something has changed after the reflash, I g'tee it has. I'm planning on the rest of the week overnight, keep it on charge (due to work anxeity, am runnong only on DRL's in the morning, no radio, lights anything, drive to my new job is 6km's one way, so 12km's today Friday night I'll take it off charge and see what happens, saturday is usually is a short trip up the road and Sunday is usually a longish drive, then back for Monday morning start. Am making sure I dont shuffle my car off the drive and stop it and then restart it. so once I'm back home, I'm back home done, no moving of cars. I wanna test out my first theroy that the key's are waking my car up overnight. INteresting, in the dealership,, car was kept for 2 days, and key's were pretty far away from the car. Also my theory about the Auto lights causing a draw, didn't happen. Anyway sorry if this was TL : DR |
10-15-2021, 04:14 PM | #81 |
Rep 1,146
I think I found a culprit, so the last time the car failed, it had rained and there was water on the bonnet, I lifted the bonnet and a deluge if water ran over the innard near the battery connector, I also noticed there is a drain point, which was blocked and smi filled with water, I remember immediately after that the when I was checking the volts, it gave weird readings, going down and down, then car died.
I also noted that after opening the bonnet I heard weird noise coming from under the bonnet, clicking and a motor type noise I am wondering if a big enough water SPLASHED something under there. Today I noticed the area (like a cup) was full of water, so I drained it, past few days I have not been checking under the bonnet and it had not been raining, morning starts have been ok (although) I have had the car on charge overnight, I'm going to investigate this further tomorrow. Last night I noticed the car would not charge fully on the trickle charger and it had drizzled/rained and I'm wondering if there is a correlation. I think this is it, I'll come back to you ALSO, I've had the key's in a faraday cage as I also thought that the key's might be waking the car up, BUT, I really think now, this is the problem Tommorow I will also check for codes. |
10-15-2021, 04:16 PM | #82 |
Rep 1,146
and the previous time to that the car died it was after we did a long run in a rain storm and after parking overnight it had rained, we parked the car up, and I'm sure that area filled up with water and overflowed
10-15-2021, 05:24 PM | #83 |
Rep 1,220
Drives: 2015 M235ix
I have a 2015 235 with the original battery.
In the last two years, I have not driven more than 300 mi./500 km. per month. Knock wood, I have had no battery issues. So something is wrong for sure with your vehicle. |
nazali1334.50 |
10-15-2021, 06:04 PM | #84 |
Rep 1,146
yeah, it's bloody crap, on a brand new car with a brand new battery, all of a sudden after 3 months of shuffling, 1 or 2 km's a day I'm told I have to drive continuosly.
I wonder how many other people have been fobbed off. BTW, yesterday it rained and the charger on all night, would not get of of phase (3 or 4) all night... this afternoon, no rain and the car charger up into full maintenance charge in an hour I'll get some pics out tommorow afternoon |
10-15-2021, 06:13 PM | #85 |
Rep 1,146
Listen, I understand the battery discharge thing, I've had it once or twice, in the 1'er
BUT your car is designed to "under discharge" to shut things off to be able to start, not totally crash out and die. BUT...BUT when your car has a short or water is shorted out then all bets are off. Also "Battery discharge when stopped" this error is that WHILE THE CAR IS STOPPED it is discharging,every time the car has died, it has been overnight, while that water has had a chance to seep in and aoverflow and go everywhere, cause a short, cause a module to crash out and flat the battery. HOW many miles you drive may or may not give you the battery discharge, but you WONT KILL THE CAR, the car wont die. That is the problem and is this problem and I bet a pound to a penny that other similar people have had this. My car also sat in a dealer for a year, that drain plug just taking water and crap. Seriously refuse when BMW tell you that your not driving the bloody car, garbage. ON a 5 year car with an original battery YES, 2020 with a 2000km battery NO, hell no |
10-16-2021, 07:56 PM | #86 |
Rep 1,146
So I'm wrapping this up, because it's gone off track, the answer is
there isn't a short trip, there is an issue and it's not with short trips PICTURES WILL BE INCLUDING |
10-17-2021, 09:42 AM | #87 |
Rep 5,393
How are you certain this is the problem? The connections there are of an all weather design and it's not like everything is sitting in water. Again, you tapped into a main part of the wiring harness and connected a device that would put a constant draw on the system AND weren't running a trickle charger when hardly driving the car.
Lastly and more importantly, as the owner of the car, it is your responsibility to maintain and clean it including those drain spouts. I inspect and clean those at at least once a month. It sounds to me that your actions are most likely the cause of your issues. |
