2Addicts | BMW 2-Series forum Technical Topics Wheels and Tires -- Sponsored by The Tire Rack Show Off Your VMR Wheels!
      12-08-2019, 08:45 AM   #705
PDM5
Drives: 2017 240i 6 Speed
Originally Posted by stratatak7 View Post
V802's in Anthracite Metallic. 18x8.5" et35 square setup (xDrive). Tires are 225/40/18 Michelin Pilot Sport AS3+. Suspension is stock and so is camber etc.
They look even better in person!
Thank you very much! Definitely solidifies my decision to pick up some 802's in Sunken Treasure come spring time for my mineral white 240. Looks absolutely fantastic!
      12-08-2019, 08:54 AM   #706
stratatak7
stratatak7's Avatar
Drives: 2016 228i xDrive M-Sport
I'm already in love. They ride so nice too. Definitely an upgrade over my stock 461M wheels! Thanks to Brandon at VMR for all the help!
      12-17-2019, 03:47 AM   #707
dsuhiti
Drives: BMW M240i
Guys, getting very frustrated. Installed my VMR 710’s on my M240i last week. Look great etc.
Noticed over 70mph I get a vibration from the car, thought it was a improper wheel balance. Took it back to the shop, still no good. Took it elsewhere to get a wheel balance and still not good!
Do I need hub rings? I thought VMR wheels are hub centric? Wheel shop used aftermarket wheel nuts, could this be the issue. Would standard, OEM wheel nuts fit?
Help would be appreciated!
18x8.5 ET35 all around.
      12-17-2019, 11:34 AM   #708
VMRWheels
General
VMRWheels's Avatar
2078
Drives: BMW
2013 BMW M3  [10.00]
2015 BMW M4  [0.00]
2013 BMW F30  [0.00]
2014 BMW F22  [0.00]
2013 BMW F06  [0.00]
There could be a few different factors that cause vibration issues. It's just a matter of using a process of elimination to isolate the issue. The wheels likely would have been drilled from the factory to use your stock lugs--lets start there. Try installing the wheels using the stock (conical seat) lugs and see what happens. If you're using any spacers, take them off. The wheels SHOULD be hubcentric, so hub rings shouldn't be required. I'm assuming you ordered from Mars Performance, so they should be able to confirm whether or not your wheels are hub centric. These are the obvious and most common culprits.
If you try the previous and it doesn't work, the issue may lie with the wheels or tires. We always recommend road force balancing the tires on the wheels to decrease the likelihood of vibrations. If the issue persists, the tires will need to be removed from the wheels and the wheels will need to be checked for trueness.
There's always a reason for vibrations--it's just a matter of properly diagnosing it to isolate the issue and fix it. Take a look at the link below for a handy troublshooting guide put together by Tire Rack. I hope this helps!
https://www.tirerack.com/images/tires/vibechart.pdf
dradernh4823.50
      12-17-2019, 02:37 PM   #709
dsuhiti
Drives: BMW M240i
Thanks for the reply. Yeah, wheels were ordered directly off Mars Performance. I will try the standard lugs that were fitted with the OEM wheels. Assuming they fit with no issues, I don’t know why the installer used 3rd party lugs. Will report back once that is done. Thanks!
      12-19-2019, 12:13 AM   #710
The Mo
South Africa
68
Drives: BMW M235i BSM
some new shots:
      12-20-2019, 08:49 PM   #711
dsuhiti
Drives: BMW M240i
Update on the vibration issue. Wheels are faulty, PCD holes were drilled slightly off centre and are not the OEM fit they were promised to be. In process of getting a refund. Very disappointed.
      12-24-2019, 03:40 PM   #712
VMRWheels
General
VMRWheels's Avatar
2078
Drives: BMW
2013 BMW M3  [10.00]
2015 BMW M4  [0.00]
2013 BMW F30  [0.00]
2014 BMW F22  [0.00]
2013 BMW F06  [0.00]
Please email us at sales@velocitymotoring.com including your order details (when and where you ordered from, who you have already contacted) so we can help resolve this issue.
      01-07-2020, 01:29 PM   #713
JD11937
Drives: 2017 M240xi
@VMRWheels I have a set of your v710ff wheels on my 2017 m240xi, 19x8.5 et35 and 19x9.5 et45. I'm running the recommended 225/35 and 255/30 tires. Wondering if it is possible to run a larger side wall without rubbing?
      01-08-2020, 11:11 PM   #714
osinko
Drives: 2014 BMW M235i
Had my V710FF's for almost a year now. Loving them
mb67413.50
      01-09-2020, 06:02 AM   #715
JD11937
Drives: 2017 M240xi
What tire sizes are you running?
      01-09-2020, 10:47 AM   #716
VMRWheels
General
VMRWheels's Avatar
2078
Drives: BMW
2013 BMW M3  [10.00]
2015 BMW M4  [0.00]
2013 BMW F30  [0.00]
2014 BMW F22  [0.00]
2013 BMW F06  [0.00]
A larger sidewall will rub for the m240i xDrive.
JD11937129.50
      01-10-2020, 06:16 PM   #717
mblaucoupe135
Drives: 2022 M240i
what about a wider tire on this setup, i.e. 235 front, 265 rear? will that rub too?
      01-10-2020, 06:34 PM   #718
VMRWheels
General
VMRWheels's Avatar
2078
Drives: BMW
2013 BMW M3  [10.00]
2015 BMW M4  [0.00]
2013 BMW F30  [0.00]
2014 BMW F22  [0.00]
2013 BMW F06  [0.00]
Without having to do modifications, 225/255 is the most that I would recommend for the M240. You may have to modify camber or fenders for anything more.
      01-11-2020, 01:51 PM   #719
mblaucoupe135
Drives: 2022 M240i
ok that's what I thought but thanks for confirming!
      01-11-2020, 02:05 PM   #720
FutbolManiac
Drives: 2017 M240i
'17 M240 Glacier Silver Metallic
New wheels on with stock suspension for now.
Front 8.5 19 43 offset with MP4S 235x19x35
Rear 9.5 19 45 offset with MP4S 255x19x30
Curious to see if next time could fit 265 if not lowering.
What should I do next? Thinking tint, carbon fiber mirror caps, cf diffuser and spoiler and then maybe paint matched reflectors.
Tune and Downpipe are coming.
      01-13-2020, 11:01 AM   #721
VMRWheels
General
VMRWheels's Avatar
2078
Drives: BMW
2013 BMW M3  [10.00]
2015 BMW M4  [0.00]
2013 BMW F30  [0.00]
2014 BMW F22  [0.00]
2013 BMW F06  [0.00]
Tint next for sure!
      01-13-2020, 11:03 AM   #722
Liandri
Liandri's Avatar
Drives: 2016 M235i
Can you post more pictures please? Close up and far away in the light? There are very few pics with glacier silver on 19" vmr and it would definitely help!
      01-13-2020, 01:22 PM   #723
FutbolManiac
Drives: 2017 M240i
Yes, I will try to get some this week and post up soon.
      01-17-2020, 05:11 AM   #724
24styles
Drives: 2019 bmw M240i sunset orange
Can someone post a square on picture of any style vmr wheel on a car but in sunken treasure and moonlit bronze? Ideally a v703 but any in those colours will do. Thanks
      01-17-2020, 08:25 AM   #725
FutbolManiac
Drives: 2017 M240i
Which spoiler/diffuser is that, M performance?
      01-19-2020, 05:25 PM   #726
Denf!
Drives: BMW m235i & BMW E46 M3
WoW! I'm considering to run a square setup with 235s... Does 8.5 ET 43 19 really fit plug and play without any rubbing issues in the front with 235/35/19??
In the back it should be a easz fit..right?
Here in Europe people are deeply concerned when thinking about running anything more than 225 in the front if 8.5J wheels are used...
Tags
9.5, fitment, v703, vmr, wheels
