05-03-2017, 07:56 AM | #45 |
Rep 222
I have a rattle in my exhaust on cold rev down that I think must be in the valve. It goes away once it warms up and opens. I think I read someone else saying similar but must not be this thread. I may just unplug it, but has anyone heard of issues here?
05-03-2017, 10:10 AM | #46 |
Rep 3,844
Yes, my car has the same exhaust rattle on cold startup. It happens about 30% of the time. I asked the dealer about it, his reply was that they all do it. I've read in another thread that the only fix is to replace the exhaust since the valve is inside the pipe, if that is true then no wonder BMW wants nothing to do with fixing this issue. It's pretty embarrassing when you start your new shiny BMW and it sounds like a 20 year old beater.
05-03-2017, 10:14 AM | #47 |
Rep 3,844
I just discovered that the rattle I thought was coming from inside the dash is actually just the cover around the steering wheel column. That discovery was a big relief, I can fix that easily.
05-11-2017, 02:25 AM | #49 |
Rep 108
No I don't know how to fix it and yes that latch mechanism rattle drives me crazy. It's such a bad design and I'm going to have it fixed next visit. If they detail the solution I will post. Going in on the 17th.
05-11-2017, 12:05 PM | #50 |
Rep 13
Same here. Engine was noisy for almost a month and the Everglide EGS solved the issues. First time that I've used a moly-graphene based oil additive and I'm pretty impressed. Have decided to try it first before getting my car checked.
05-11-2017, 12:14 PM | #51 |
Rep 5,580
05-22-2017, 11:01 PM | #53 |
Rep 796
15k miles. No rattle. Almost pulled the trigger on a S550. Potential for rattles kept me from it. Very happy with the 235.
'16 235i
'15 3500 HD Dually '13 C4S |
05-27-2017, 07:06 PM | #54 |
Almost completely sane
695
Rep 1,080
Rattling from the horizontal panel between the rear seats and the rear window.
Sounds like two license plates or other thin metal sheets clattering against each other. Only on medium/large bumps. 2017 M2.
'17 BMW M2 (BSM 6MT Exec CarPlay, TechnicPnP ASD bypass, IND M Perf shift knob + keyhole cover, Pedal Haus pedals + heel plate, 3M CR90 tint, BavSound Ghost woofers, Racing Dynamics strut tower brace, Dinan midpipe, Turner intercooler)
'00 Honda S2000 (Silverstone Metallic, black leather, factory titanium shift knob + front lip + trunk spoiler, front shock tower brace, front subframe x-brace) |
07-05-2017, 12:02 AM | #55 |
Rep 108
In case I wasn't clear a major source of rattling is not the glove box itself but the wood trim and the accent trim pieces above the glovebox. It's amazing how loud they can rattle when the temperature changes. I need to take it back in to fix it. It's probably the worst rattle in the car so far.
07-06-2017, 02:09 PM | #56 |
Rep 555
So best advice I can give you guys, and this is how ive had mine taken care of. If you have a passenger with you, just record the rattles with your phone or camera etc.
I have had 2 or 3 that popped up over time. There is 1 persistent one that they just cant seem to fix. Rattle in passenger door panel, and also sounds like the glove box latch rattles a bit over bumps.
07-06-2017, 02:24 PM | #57 | |
Rep 108
07-06-2017, 04:45 PM | #58 |
Rep 102
I had a horrible rattle going over certain pavement grades/bumps..not even bad bumps, just certain kinds of bumps made this really metallic clanging. Turned out to be the child seat secure mounts were banging around. They added some padding and the rattle went away.
07-07-2017, 01:26 AM | #60 |
Rep 51
I have some minor rattle coming somewhere from passenger side, suspecting the right side of sun roof, but possibly in the door as well. Will try to report it next time I go for service.
07-10-2017, 04:34 PM | #62 |
schmember
22
Rep 58
Just the usual "snap crackle and pops", especially in extreme weather changes (i.e. 100° weather and blasting the AC causes the dash and vents to make a lot of adjusting / cracking sounds). Also changing lanes on the highway and hitting the reflectors on the road makes the middle of the dash sound like it's going to break in half (ha). Chalking it up to LA freeways just being garbage roads.
But I've learned to just live with it. I also noticed a lot of these noises when driving the 320 and 328 loaners when my car was in the shop. Last edited by xojustin; 07-10-2017 at 04:35 PM.. Reason: Spelling |
07-11-2017, 10:44 AM | #63 |
Rep 2,882
I found that my interior really 'throws' the noise - so it sounds like it is coming from someplace very different from actual origin. So far I've been lucky and w/o any major rattles, but I spent a frustrating 3 days chasing an under-dash rattle that turned out to be from my garage opener (on the visor). Having a second set of ears, or riding shotgun can help, and systematically removing things or holding them down to figure out what stops it. And as far as I can tell, ANYTHING that you put in that left dash hideyhole will sound like a box of rocks, no matter how you try to keep it solid.
07-17-2017, 11:23 PM | #64 | |
Rep 157
to occasionally wipe down the instrument lens, iDrive screen and the piano black around the HVAC controls that always seems to get finger-printy. |
07-18-2017, 08:53 PM | #66 |
Rep 9,788
