08-28-2023, 09:38 PM | #5325 | |
Thaumaturge
181
Rep 211
I change the Cabin Air Filter and wiper blades once a year on the FCP Euro warranty plan. And no, I don't send back oil and filters. ///Rich |
08-29-2023, 08:19 AM | #5326 | |
Rep 338
JMcLellan2135.00 |
08-29-2023, 02:22 PM | #5327 | |
Rep 1,146
the splitter is "splitting the air, making it cut through faster, but I would have thought the effect is only at higher speeds or tracking... how fast are you driving on public road my good man
08-29-2023, 03:18 PM | #5328 | |
Rep 1,248
I don't know what else this behavior would be from. Tire pressures are the same, tuning settings were the same, temps the same. I'm assuming it's the splitter since that has been the only change.
2024 M2
2019 M240i- Sold |
08-29-2023, 03:41 PM | #5329 | |
Rep 1,146
next step would then be the spoiler !
JMcLellan2135.00 |
08-29-2023, 03:43 PM | #5330 | |
Rep 1,146
sounds like some things only come in pairs, you know like "Hookers and Coke"
08-31-2023, 10:14 AM | #5332 | |
I like biscuits
164
Rep 250
08-31-2023, 11:49 AM | #5333 |
Rep 391
Hmm I have the same, again above 70mph, had the wheels aligned when I got the car and it's still there! Can I check myself if the wheel is bent?!
Current: G20 320d xDrive F22 M240i
Previous: Many, many boring BMWs, 116d (F20), 220d, M240i (F22), 318d (F30), 320d (F30 and G20), 330e (G20), 420i (F32), 420d (F32), 435d GC (F36) |
08-31-2023, 12:01 PM | #5334 | |
Rep 1,830
I'm going to wait until my winter tires go on to investigate further. The vibration seems to have gone down in severity but I also might just be getting used to it. It seemed to start after an alignment (at the dealer) so maybe the unworn areas were being evened out or something. |
08-31-2023, 12:16 PM | #5335 | |
I like biscuits
164
Rep 250
You can also do it with the wheel on the car, and use the strut as your straight-edge to measure against. |
09-01-2023, 12:44 PM | #5336 |
Rep 106
Upgraded M3
I did this about two months ago. But after owning 230i, M240i, and M2C, I finally pulled the trigger on my dream car. I will be back someday, two fam <3
09-07-2023, 10:22 AM | #5337 |
I like biscuits
164
Rep 250
Recently installed 10mm spacers all around. Really helped set off the stance, and compliments the drop!
....Yes, my hood is damaged. |
09-11-2023, 02:51 PM | #5338 |
Rep 51
Drives: '24 M3 CS, '18 M240xc
installed these label-less visors after watching this howto video. 5 minutes total.
after looking at the gloriousness, i couldn't help but want to hug the PaddleShifterz crew. they usually don't carry the visors, but the sourced them because i asked. |
09-12-2023, 10:22 AM | #5339 | |
Rep 1,830
09-15-2023, 10:59 AM | #5341 |
Rep 447
I'm not msendit, but I can confirm that heading into Turn 1 at Thunderhill East at 120mph there's a ton more confidence with a splitter and wing. I would assume it makes an even more pronounced difference at a track like Big Willow where a fast car can hit 150+ mph.
JMcLellan2135.00 freakystyly3085.00 |
09-15-2023, 04:37 PM | #5342 | |
Rep 3,507
We barely made that wing work running it flat (0°). Creating sufficient front downforce to balance it took a lot of time and testing. The E36 wasn't a very flexible platform in that regard. The last card we had to play was going to be running the wing negative at up to -1.5°. Afterwards, it was clear that the SM183 wing would have been a more appropriate choice. I'd run a couple of the standard wings on offer and had found they didn't give me what I wanted. These are the wings that come with uprights, end plates, and typically bolt to your trunk lid. We bought the wing's end plates from DJ, and the shop made uprights that placed the wing where we wanted it. The uprights ran through the trunk lid and were bolted to the rear subframe. There was absolutely no flex in the assembly. It had been explained to me that the wing should be mounted such that it could be used to push the car around. On the other end, the splitter was required to be mounted firmly enough that it should have no deflection when hundreds of pounds were applied to it, whether from downforce at speed or from having three people standing on it to test to see if it would remain flat. Below are some photos. DJ Engineering SM203 End-Plate Mounting Surface DJ Engineering SM203 Mounted with Decklid in Place DJ Engineering SM203 Mounted with Decklid Removed DJ Engineering SM203 Upright Trunk Support Structure DJ Engineering SM203 Upright Trunk Support Structure Rear Attachment Points Closeup Depth-Adjustable MDO Splitter
09-15-2023, 04:57 PM | #5343 | |
Rep 323
What speed can you notice ... depends on how much you crank up your wing/splitter. You sometimes see autocrosers (think 20-30 mph) with wings cranked up at 20 degrees angle-of-attack, presumably that makes a difference -- although there's no free lunch, it will be a draggy parachute at 80 mph. In a competitive environment, we do lots of testing to set a reasonable AoA. But yea, it can easily make a 0-5 mph difference in corners as slow as 60-70. Whether it makes sense on the street / doing hard lane changes / whatever is a different question. Of course not. If you're only using 5% of the available traction, sure you can add 10% to the limit. Congrats, now you're using 4.5% of the available traction.
09-18-2023, 09:06 AM | #5344 |
Rep 1,248
I'm a big fan of the Meguiars Mirror Glaze product. It took about an hour to apply to my car. Shined it up really nice.
Link: https://www.amazon.com/Meguiars-Mirr...79512156&psc=1
2024 M2
2019 M240i- Sold |
cdn240cab38.00 |
09-19-2023, 12:55 PM | #5345 |
Rep 51
installed the Carbonex hood latch. if you can use a Phillips-head screwdriver you can install one. when i took it out of the box it seemed impossibly big and it had a nice heft in the hand. when i pull it, it feels like i am throwing an old-skool breaker in an a mad-scientist lab.
skidplate21.00 |
