02-13-2014, 11:34 AM | #419 | |
Rep 524
I do agree with your premise about there being good and bad examples of each approach (I have driven manual steering cars that were lousy, but that's rare). And I agree that a 981 is a reasonable example of electric, but was still a big letdown from the 987 (as you said).
1973 Porsche Carrera RS 2.7 Carbon Fiber (240hp & 1,890 lbs)
02-13-2014, 12:16 PM | #420 | |
Rep 3,070
All in all I have to agree that in time they will be much better and maybe better than any hydraulic system; just can't say that it looks sometime close enough to make me believe that steering of the next M2 will be better than what I already have. If the rest of the car will be too good you may always forgive/ignore this or that though.
"The mark of a great car is one whose overall competence exceeds what you should expect from its individual components and the 1M does just that", Chris Harris.
BMW 1M-SOLD-: TECH: Evolve Race+N55mids, Evolve IC, Michelin PSS, ER cp, aFe filter, CDVx, Vorshlag camber plates, BMS OCC EXTERIOR: trunk spoiler, blacklines, black grills, IND goodies INTERIOR: Alcantara steering wheel, steel pedals, custom mats, MPower e-brake. Last edited by ozinaldo; 02-13-2014 at 12:22 PM.. |
02-13-2014, 12:21 PM | #421 | |
Rep 524
It seems to me that if electric steering had so much potential then the results would start to reveal that by now. I guess BMW M is one of the last performance marques to show us that potential. I wish I was a little more hopeful...
02-13-2014, 12:33 PM | #422 | |
Rep 3,070
http://en.wikipedia.org/wiki/Power_steering
BMW 1M-SOLD-: TECH: Evolve Race+N55mids, Evolve IC, Michelin PSS, ER cp, aFe filter, CDVx, Vorshlag camber plates, BMS OCC EXTERIOR: trunk spoiler, blacklines, black grills, IND goodies INTERIOR: Alcantara steering wheel, steel pedals, custom mats, MPower e-brake. |
02-13-2014, 12:44 PM | #423 |
Rep 524
BTW, if after time it becomes clear that hydraulic is simply superior to EPS (even with software tweeks), there is a solution.
All factory Porsche race cars and the McLaren 12C (maybe the P1 also) use hydraulic steering where the pump is driven by an electric motor, instead of by a belt from the crankshaft. This gives all the advantages of hydraulic steering feel and all of the economy of EPS. There is a little extra weight and complexity, but well worth it until (if?) EPS improves to equal or better the performance of hydraulic.
02-13-2014, 01:01 PM | #424 | |
TIM YOYO
1505
Rep 3,282
Drives: 2013 M3
I still believe that the problems with the EPS systems we've seen to date are all engineering related, not systemic.
His: 2019 R1250GS - Black
Hers: 2013 X3 28i - N20 Mineral Silver / Sand Beige / Premium, Tech Past: 2013 ///M3 - Interlagos Blue Black M-DCT Past: 2010 135i - TiAg Coral Red 6MT ///M-Sport |
02-13-2014, 01:01 PM | #425 | |
Rep 9,160
02-13-2014, 01:32 PM | #426 | |
Rep 78
02-13-2014, 02:29 PM | #427 | |
Rep 524
This would require the motor's pinion gear to mesh and disengage (like a starter motor does from the flywheel's starter ring's teeth when starting the car) and could potentially be a point of wear or failure. But, I think the benefits would be considerable.
02-13-2014, 03:02 PM | #428 | |
Rep 1,317
The ZF8 is brilliant as far as slush boxes go, but it's still not DCT.
2017 X5 4.0dSE ~ Atlas Cedar:Ind.Amaro Brown Merino&Piano Blk, Sport Auto, DHP, Comfort seats, Cold weather pack, HK audio, Electric towbar, Sun protection glass.
02-13-2014, 03:04 PM | #430 | |
Rep 524
But since you live in London, I'll give you a pass. I used to live in Los Angeles and a Manual is a little trying there as well...
02-13-2014, 03:05 PM | #431 |
Rep 524
It has to be cheaper than M3/M4, so I'm thinking around $56,500 in today's money.
02-13-2014, 03:14 PM | #432 | ||
Rep 1,317
I love manuals, but I can't remember a decent manual box in a modern car that I've driven..... I'm sure there must be some? I've spent quite a bit of time driving in and around LA, and I think London is now much worse than LA, and I'd never have a manual again as a DD.
02-13-2014, 03:18 PM | #433 | |
Rep 524
02-13-2014, 03:59 PM | #434 | |
TIM YOYO
1505
Rep 3,282
Drives: 2013 M3
I just don't see that happening though. Not only is a clutch system going to be more prone to failure, but a fully manual rack in a modern car is just not sensible. It's fine in a 2,500 lb rear-engine 70's Porsche or a 2,000 lb Alfa 4C, but in a 3,000+ lb BMW, they'd have to use a horrible ratio. No one wants to go back to 6 turns lock-to-lock You just don't want so much assist that you can't feel anything, and you want less assist when the steering is naturally unloaded.
02-13-2014, 04:00 PM | #435 | |
TIM YOYO
1505
Rep 3,282
Drives: 2013 M3
02-13-2014, 04:52 PM | #436 | ||
Rep 1,075
Current: F87 M2 MT MPE, E84 PP SP LP
Previous: F30 - 335i AT, E90 - 335xi MT, E90 - 330i MT, E46 - 330i MT |
02-14-2014, 08:52 AM | #437 | |
Rep 455
02-14-2014, 11:50 AM | #438 | |
Rep 524
02-15-2014, 09:16 AM | #439 |
Rep 455
Those with M car experience, is it a good DD or something for track mostly? Just thinking maybe the 235i may be better for DD use. Let me know some thoughts...
02-15-2014, 11:40 AM | #440 | |
Rep 5,874
