01-23-2019, 11:35 AM | #23 | |
Rep 14
01-23-2019, 11:35 AM | #24 | |
Rep 823
01-23-2019, 11:54 AM | #25 | |
Rep 14
you didn't lay anything out, you just gave instructions on how to take the panel off...which again, i agreed with you in your first comment, that ill do. in case you forgot, i said: "thats what its lookin like" in response to you: "...just pop the panel off.." im "not doing it"? what exactly am i supposed to be doing now? i dont know whats causing it...the point of the post. im not gonna just take the panel off for no reason, to explore the the vast beauty of the door shell. another user said its the motor track, so now i have a general area to work on/look towards. |
01-23-2019, 12:10 PM | #26 | |
Rep 823
01-23-2019, 12:16 PM | #27 |
Rep 5,394
The grease is likely coming from the track and window motor system.
http://www.realoem.com/bmw/enUS/show...diagId=51_8735 No one is going to exactly know the source unless you completely disassemble the door which, at least to me, seems crazy given that wiping the glass takes a couple of seconds. Are you loosing your mind with the rust inhibiting grease that's oozing from the metal panels as well?
01-23-2019, 12:53 PM | #28 | |
Rep 14
You said no one knows what causes it. Not true. You...don’t. not, nobody knows. And, I know it doesn’t affect you. I read your first comment.... Refuckinlax |
01-23-2019, 05:29 PM | #29 | |
Rep 1,363
01-23-2019, 06:13 PM | #30 |
Rep 54
I appreciate you posting about this. I thought I was going crazy seeing smudges on my clean windows.
Thanks for bringing this issue up. I just keep a micro fiber towel in my side pocket and wipe the window as necessary.... |
01-23-2019, 08:36 PM | #32 |
Rep 5,115
Wow...this old issue. There's actually a thread for this, probably dating back to ~2014 or thereabouts. Had the dealer investigate twice (no charge), but never got to the root cause.
Just cleaned the glass every few days. Problem solved.
01-26-2019, 08:38 AM | #34 |
Rep 6,087
Sorry...buzz, squeak, rattle. Every off/on cycle of the trim panel stresses the attachments and increases the chances for these (for me) highly annoying sounds. Much easier to just wipe the glass than chase/resolve new door trim noises.
01-27-2019, 12:45 AM | #35 |
Rep 260
Thanks, and I agree. Also for OP; I took off both door cards recently. One was simple but the other was a nightmare due to a free-spinning plastic nut on the other side. Removing the sound insulation and replacing with new butyl isn't going to be much fun either. The sound insulation tears easily.
01-31-2019, 08:05 AM | #37 |
Rep 69
Drives: 2014 M235i AW
Mine too. I thought it was tint damage but its grease.
2014 BMW M235i AW
1998 Porsche 911 2007 Mercedes E350 Wagon 2001 Toyota MR2 1977 Lancia Montecarlo 2002 Acura RSX Type S |
