01-05-2016, 09:37 AM | #23 | |
Rep 191,471
map 1 stock car with JB4 map 2 DP + Jb4 Map 7 FBO + E30
01-11-2016, 12:49 PM | #25 |
Rep 191,471
High flow cats will work as well
01-12-2016, 04:16 PM | #27 |
Rep 191,471
01-17-2016, 12:12 PM | #28 |
3442
Rep 79,211
JB4 is still the more popular tune. Great bang for the buck.
Our other biggest seller is AA Active 8. If you plan on going further with downpipes and intercooler you'll likely find JB4 more appealing as it can handle the catless downpipes CEL and optimize for more power with other modifications. Only thing better then that would be a custom flash. |
01-25-2016, 03:28 AM | #29 |
Rep 2,379
The JB4 is truly amazing.
Here are my three pros and cons: Pros: Versatility - you can do custom maps or let it adapt to your fuel by itself, it can also control your meth system User interface - you can keep an eye on things via your mobile and log to check that all is running as it should + switch maps via the car controls Support - there is a huge community to support you and you will get personal support if needed by the man Terry himself Cons: Build quality - not impressive, I have had several corrosion problems Plug'n'play - not so much unless you just run map1 or 5 and even then you might have problems, you will have to do some studying to get the most of it
M135i 8AT PWG, MHD, Pure Stage2, WMI via Torqbyte CM5-LT, Custom tuned by PureBoost
(A Dane in China) |
01-25-2016, 04:06 PM | #30 | |
Rep 191,471
https://x-ph.com/sale/ Phone number 702-494-9435 Last edited by mike@x-ph.com; 01-25-2016 at 04:17 PM.. |
01-25-2016, 07:31 PM | #31 |
Rep 2,379
Its not quite good enough for me to use computer grade connectors on an automotive product. The MegaSquirt does the same which is why I exchanged that with an OMEX. I love everything else about the JB4 which is why I still have it and recommend it to others.
(A Dane in China) |
Tags |
downpipe, ess, intake, tune |
