2Addicts | BMW 2-Series forum BMW 2 Series (F22) Forum BMW 2 Series Coupe and Cabriolet (F22/F23) General Forum Do I need a spacer for 255 tires 18x9.5 et45 wheel
      04-02-2018, 08:32 PM   #23
Acalamito321
Drives: M235i x drive black/red
Originally Posted by aozer View Post
post in the regional forum and see who other people in NYC use
Thank you
      04-05-2018, 04:15 PM   #24
Acalamito321
Side note: anyone know the ideal tire pressure for front and back for this setup
255 rear
225 front
Xdrive
      04-05-2018, 10:12 PM   #25
Acalamito321
Originally Posted by Luftwaffe1O1 View Post
Originally Posted by Acalamito321 View Post
No pepboys said that I don't believe them because there's a bunch of ppl on here running this setup, the cars going to bmw Wednesday and after that I'll take the spacers off myself that night
Yeah I have no idea why they would think you need a 12mm spacer, when mounting the wheel on it should be obvious it will fit when the car is up in the air.
My guess is they are just unfamiliar with the offsets? Maybe they just don't know how to add? I think our stock offset is something like in the 50s? et58 maybe? Could they have added it wrong thinking its positive offset and adding a 12mm spacer would bring it closer to OEM?
edit: just to clarify on top of that, our cars have negative offset. So that et45 is -45. By adding a 12mm spacer, it changes the offset to et33. Which is WAY out of what it should be in the rear. At et45 we are pushing poke, for 9-9.5 inch rear wheel the 51-48 range is a bit better, but 45 still fits rather nicely, albeit with a couple of mm of poke.
At et33 with 9.5 inch wheels, you are going to look like a cholo truck rolling around.
There's no difference between xdrive and rear wheel drive here thought right? My car is xdrive
      04-05-2018, 10:14 PM   #26
Acalamito321
i had AG M359 wheels in 18x9.5 et45 in the rear and it poked way too much. even without spacers it looked stupid, i cant image how bad it would look with spacers.
Do you know if the spacers would negatively affect handling or anything else the way I have them right now?
