BMW M2 Forum > BMW M2 Competition Model > S55 Engine Tick in 2024
      04-09-2024, 07:04 PM   #23
chris719
Drives: '08 M Roadster
Originally Posted by m2ss View Post
Is this "ticking" sound only on start up or at all times even when warmed up?
I have to check...
Unless it's bad, it can only be heard when cold or warming up. The easiest place to hear it is actually at the passenger wheel. It's easier to hear once the high idle settles a bit but while the engine is still cold.
      04-17-2024, 12:26 AM   #24
Brandt51
Flavor of the month
Brandt51's Avatar
952
Drives: BMW F87 M2C
2020 BMW F87  [9.50]
Narc that scumbag dealer out. With BBB and BMW. That’s unsat.
Thanks for the list, that’s wild tho.
Samuel of the Internet
2023 F98 X4M Comp
2023 F95 X5M Comp
2020 F87 M2 Comp
      04-29-2024, 01:03 PM   #25
SCM2C
SCM2C's Avatar
Drives: M2C
She’s Finally Here! Valve Cover goes on today and injectors get dropped in. So excited to get my little monster back. Looks like it got a set of aftermarket valves too. Excited to see what we can do with this bad boy!
This will likely be my final post unless anyone has any other questions. I’ll try to check periodically.
      04-29-2024, 06:25 PM   #26
ps2cho
Drives: F10 535
Just bought a 2021 M2C and I dont remember this noise when I purchased it....but I thought something didnt sound right, googled and found this thread.
Would you mind listening to my video and tell me if this sounds very similar?
I have an 535i N55 so I know what injector tick sounds like, this isnt injector tick on this M2C...this is clearly a lifter or exhaust cam.
Have all dealer records and still under warranty for another year, so I'll drop it off if you think this sounds similar (give it 10mins to upload)
https://youtube.com/shorts/FPtrpdNiGJk
SCM2C67.00
      04-29-2024, 06:30 PM   #27
SCM2C
SCM2C's Avatar
Drives: M2C
I have an N55 so I know what injector tick sounds like, this isnt injector tick, this is clearly a lifter or exhaust cam.
That sounds pretty similar to what I experienced. Does it do it when it’s warm and increase with engine speed? I could always hear it with the windows down driving past a fence and it kinda faded into engine noise around 3k RPM
chris7197393.50
      04-29-2024, 06:31 PM   #28
SCM2C
SCM2C's Avatar
Drives: M2C
Shes blue!!!
m2ss1869.50
Shaq9312.00
      04-29-2024, 06:51 PM   #29
ps2cho
Drives: F10 535
Yes does it while warm too, after more searching I am pretty convinced I have the same issue going on with the cams. I'll drop it off at the dealer and tell them to reference the PUMA case #.
      04-29-2024, 07:11 PM   #30
SCM2C
SCM2C's Avatar
Drives: M2C
I wish you luck, hopefully no damage.
      05-01-2024, 08:20 AM   #31
SCM2C
SCM2C's Avatar
Drives: M2C
Engine goes in today! Inching closer to being back on the road.
MSH_136.50
Shaq9312.00
Distinct165.00
      05-02-2024, 05:16 PM   #32
bitcore
bitcore's Avatar
108
Drives: F87 BSM Manual M2 Comp
Awesome!
What shop is helping you with this?
SCM2C67.00
      05-08-2024, 08:49 PM   #33
ps2cho
Drives: F10 535
Not to highjack thread but my M2C confirmed dealer is opening up the engine to look at exhaust cam bolts, thanks for the thread info this helped me steer them. They gave no pushback and agreed the noise was not normal. I am very confident I caught this almost at the moment it began, no more than 30-35 miles since it started it, and oil is fresh so damage if any should be minimal.
SCM2C67.00
chris7197393.50
      05-08-2024, 08:51 PM   #34
SCM2C
SCM2C's Avatar
Drives: M2C
Originally Posted by bitcore View Post
Awesome!
Mad Gas in CHS
      05-08-2024, 08:53 PM   #35
SCM2C
SCM2C's Avatar
Drives: M2C
I say keep the updates coming, help as many peopke as possible
87M34.50
      05-10-2024, 08:27 PM   #36
ps2cho
Drives: F10 535
Got my M2 back all fixed! They did a Tsara case and replaced cam carrier bolts. I’ll make a fresh thread with before/after videos for others along with all the parts and steps the dealer did if someone’s out of warranty.
Appreciate 4
philth263.50
chris7197393.50
SCM2C67.00
      05-12-2024, 08:08 PM   #37
lemansbluef82
lemansbluef82's Avatar
14
Drives: 2020 M4 Comp LeMans Blue
  [9.83]
Adding to this thread, I've been experiencing the same ticking noise, mine is quieter on idle so I'm hoping I'm catching it early on and avoid an possible damage/rebuild as I'm out of factory warranty already and rolled the dice on no extended warranty.
2020 M4 26k miles completely stock
Here are videos of mine from the engine bay: https://youtube.com/shorts/01s1fcZjtLE & https://youtube.com/shorts/dPYD3-vM6rc
I also found another M2 comp with same noise I have:
I'm taking it to an independent shop tomorrow to get it diagnosed and hopefully fixed. Will update this thread with the results.
SCM2C67.00
chris7197393.50
      05-13-2024, 11:21 PM   #38
lemansbluef82
14
  [9.83]
UPDATE: The independent shop didn't want to touch it / teardown so they sent me to the dealer. Dealer came back saying metal shavings found in the oil filter so I'm expecting the worst right now with needing a new engine if it's not savable. Teardown will begin tomorrow to see if the technician can find the source of what's causing the damage. My first and probably last BMW given how poor my experience has been in only 2 months of ownership. Car is out of warranty so options are limited at this point.
      05-14-2024, 05:59 AM   #39
joshuawi99
Drives: M2C
Im curious for the teardown results. Typically the exhaust camshaft problem can be heared perfectly while idling (As shown in the example video). Yours only makes noises while giving it some revs which is rather strange.
      05-14-2024, 06:08 AM   #40
joshuawi99
Drives: M2C
Sorry for the double post but I have a quick question regarding your fault case. Your pictures shown a the beginning of this thread shows the intake cam not the exhaust camshaft? The exhaust carrier looks completly different because its a closed unit, not single caps....
chris7197393.50
SCM2C67.00
      05-14-2024, 07:13 PM   #41
lemansbluef82
14
  [9.83]
Update 2: foreman reached out to bmwna for a second opinion and it recommending to loosen then retorque camshaft bolts per TSARA. I assume it’s the bolts on the ledge covering the camshaft itself once you remove the valve cover. I’m not sure if that ledge needs to come off and more bolts underneath need to be torqued as well but bmw Bellevue is quoting me 5k (lol) to take care of the issue. Looking to see if an independent shop is will to take care of it.
SCM2C67.00
      05-14-2024, 07:26 PM   #42
chris719
The ledge bolts are TTY and should be replaced not retorqued. The job does not look all that hard so I'm sure an indy with experience with N54/N55/S55 could do it.
      05-14-2024, 07:27 PM   #43
lemansbluef82
14
  [9.83]
That’s what I’m thinking as well based on the torque spec so proper way would be with fresh bolts.
chris7197393.50
      05-16-2024, 06:13 PM   #44
lemansbluef82
14
  [9.83]
Update 3: took it to another independent shop and they confirmed the same on the camshaft ledge bolts needing replacement and torquing. Better price than the dealer but still want 3k for the whole job. Labor rates are quite expensive in Seattle so I don’t think I will get much better of a rate. I’ll know in a few days if everything worked out.
chris7197393.50
m2
