BMW M2 Forum > BMW M2 Discussions > 2016 BMW M2 (F87) is a Go! Coming Late 2015 - Early 2016
      05-01-2014, 08:40 AM   #287
vladberca
vladberca's Avatar
Romania
769
Drives: '18 octavia 2.0 tdi dsg
The engine of Alpina B4 is based on the N55 one too. What's not good with it?
Curious to see if the next RS3 will be on par with Golf R400 as the S3 is with Golf R. A lot of great models in the near future
      05-01-2014, 09:00 AM   #288
jippii ensio
Drives: 335i
The new engine for M2 will be a real gem. It is different from the N55 as we know it currently and similar to S55 in certain respects. Best of both worlds.
      05-01-2014, 09:01 AM   #289
Mavus
Mavus's Avatar
2040
Drives: E90 335i, F80 zcp
Originally Posted by riM3
Originally Posted by CanAutM3
Originally Posted by SCOTT26 View Post
It won't cannibalize the M3/M4 because by the time it arrives on the market.
Both will be around two years old and heading for the next progressive step.
This is an important piece of information.
Comp pack?
This means they don't have time and personnel to tune S engine due to X9 and 9 series but yet they want to capture sales. Once those two models are developed the M2 LCI will get S engine and other tweaks. This is the one I am waiting for. My guess only. This is what happens when you have gazillion models.
      05-01-2014, 09:22 AM   #290
pkimM3r
pkimM3r's Avatar
209
Drives: m3 saloon in granny mode.
Originally Posted by nachob View Post
Single turbo models have better throttle response.
Where did you get that from ?
bigger turbos have more lag. two smaller ones would have better response right?
      05-01-2014, 09:29 AM   #291
Hellkite
Hellkite's Avatar
Drives: 15 M4 manual
They really need to put a detuned S55 instead of a N55. the N55 blows after 360. I would worrie about reliability. Even tunners are are replacing the cranks rods and pistons on the M235i just to get 400 +. If Bmw puts the N55 into the M2 it will be the worst m car ever. The m2 also needs a serious diet, it can't weigh as much as the m235.
      05-01-2014, 09:38 AM   #292
j23a45m
j23a45m's Avatar
Drives: 2012 E70 X5
Originally Posted by CanAutM3 View Post
The S55 used the N55 as a a starting point. It has a new block, oil pan, crank shaft, rods, pistons, head, turbos, intercooler, etc... There is not much left in common with the N55 except the bore, stroke and cylinder spacing.
pretty much what i was pointing out!
thank you
2011 BSM 335i E90 MTECH 6MT • JB4 stage 2 iso 5.3 FF wire• BMS Intake • Vishnu DP • Cyba Scoops • LUX V4 • 6000K Headlight/Fog light Philips Ultinon • Euro headlight switch • ACS roof wing • 35% tint • Performance Grilles • Misc coding • Cobb charge pipe • ///M3 fenders • 335is pedals • BC Coilovers • Vrsf 7" IC • ///M3 mirrors •
      05-01-2014, 09:58 AM   #293
nachob
Drives: 2004 330i ZHP, 2022 Cayman T
Usually, yes, it takes less exhaust to spool them up quicker. Downside, is less final boost. That is why they use two small ones on N54.
Also, someone asked where did I get that. Car and Driver tested N54 and N55 side by side and they found quicker throttle response. My butt meter confirms it. I jumped from my 2011 1M to friend's 2011 335i and throttle response quicker. I think CD article was around 2010. The single turbo uses two exhaust scrolls instead of 1 like older turbo so you have a smaller exhaust pass-through which maintains exhaust velocity. Older turbos had all 4,6,or 8 cylinders feeding a single exhaust scroll. That is why the call the BMW turbos Twin-Turbo. It's a single turbo with twin scrolls power the compression impeller. Great idea.
      05-01-2014, 10:49 AM   #294
pkimM3r
pkimM3r's Avatar
209
if a 335i has good response, the 1m coupe i would have to say suffers from some shitty turbo lag. i always thought this wasnt the case. this is why i love the m3 and its awesome engine. hope the new m2/3/4 have addressed this.
      05-01-2014, 10:55 AM   #295
nachob
I wouldn't call it shitty. I have driven those type of turbo lag cars. The 1M is actually pretty good BUT the throttle response is slightly quicker on the N55. The two turbo setup lets them get more power easily because you have small turbos for only three cylinders. The single turbo has to feed all six so there is the potential that if they increase the size to make more boost, it also will have more lag. Personally, I prefer NA motors and would give up a few horsepower for quicker more linear throttle response but most people just want the big number. With all that said, the 1M is such a bitchin' car that you can easily overlook a little bit of lag.
Automobile Magazine Comparison
Page 2 Quote: "On the street, after driving N54 and N55 cars back to back, it's definitely safe to say that the N55 suffers from even less turbo lag than the N54 did. And that engine set the benchmark."
http://www.automobilemag.com/reviews...5is_dyno_test/
      05-01-2014, 10:58 AM   #296
CanAutM3
General
CanAutM3's Avatar
Drives: 2021 911 turbo
Originally Posted by j23a45m View Post
You do know that the new m3/4 is using pretty much a N55 just with 2 turbo's right?
thank you
Not really.
You said that the S55 is an N55 with two turbos. It is not.
      05-01-2014, 11:02 AM   #297
CanAutM3
General
CanAutM3's Avatar
Originally Posted by riM3 View Post
Comp pack?
Comp pack or some sort of engine LCI as we saw on the E36 M3 (3.0L -> 3.2L).
      05-01-2014, 11:03 AM   #298
CanAutM3
General
CanAutM3's Avatar
That is my understanding too.
      05-01-2014, 11:09 AM   #299
W///
W///'s Avatar
7532
Drives: F82GTS, E36/E92M3, Z4M
Everyone's talking about increasing the power, and throwing a tune on it. I really couldn't care less to be honest. I'm perfectly happy with an N55 (and we don't even know what upgrades or what they'll do with cooling system).
Orange/Cloth/6MT
LED headlights if available during LCI
Comp Pack if it becomes available.
That's it.
The key word here is make it as light as possible. With 380hp, I'm more than happy with that. Would be the perfect companion for my E92 M3. It really is time to start saving up.
Current:
16 F82 M4 GTS, Black Sapphire/Black, DCT
08 E92 M3, Sparkling Graphite/Bamboo Beige, 6MT
07 E85 Z4M Roadster, Alpine White/Red, 6MT
99 E36 M3, Techno Violet/Dove Grey, 6MT
      05-01-2014, 12:01 PM   #300
nachob
Orange/Cloth/6MT
That's it.
+1
      05-01-2014, 12:04 PM   #301
kmarei
kmarei's Avatar
Egypt
689
Drives: 2018 Audi RS5 coupe
2018 Audi RS5  [0.00]
Originally Posted by IEDEI View Post
MEH. the 1M is a waaaay more desirable car than the M3 of that time.......proof that tradition does not equate to the final product.
tradition only matters if you're stuck in the past...
on what facts are you basing the argument that its more desirable?
cuz I cant think of any
      05-01-2014, 12:08 PM   #302
kmarei
kmarei's Avatar
Egypt
689
Originally Posted by Blipit_ View Post
Not so sure of that.
The 1M doesn't suffer from boxster-itis.
the 1m was a stop gap model rushed to production, produced in small numbers to generate some hype for this model
so it was never a threat to the m3
this one will sell in larger numbers, so I think it is a bit of a threat
especially that they basically use the same engine
yeah I know s55, but s55 is basically an N55
some of us fall for the marketing hype, others don't
      05-01-2014, 12:33 PM   #303
ChrisNich117
ChrisNich117's Avatar
Drives: '14 F10 M5 Alpine White ZCP
2009 e92 M3 coupe  [0.00]
2013 F10 M5  [0.00]
Those 1M prices won't be without depreciation any longer I suppose.
      05-01-2014, 01:12 PM   #304
Robin_NL
S0THPAW
Robin_NL's Avatar
8784
Drives: HS M2 Competition
Comp pack or some sort of engine LCI as we saw on the E46 M3 (3.0L -> 3.2L).
E46 M3 had from the beginning a 3.2 litre engine through the whole cycle of the model. From 343BHP to 360BHP (CSL)
I think you mean E36 M3: E36 came first with 286BHP 3.0 and later on (LCI) the 3.2 litre (SMG1 gearbox) 321BHP (which I back then testdrove as one of the first worldwide in Germany, I was working at a BMW dealership back then))
Cheers
Robin
      05-01-2014, 01:40 PM   #305
SCOTT26
SCOTT26's Avatar
5323
Drives: A big F-off German Truck.
Originally Posted by alpinweiss 335i View Post
I'm all for xDrive ///M cars. M2, M3, M4, M5, M6 ... why not! AWD is the future of performance. You can only put down so much power to 2 wheels, before the nannies kick in and kill the party.
As an option of course, not standard. Just like DCT/MT. Not all of us are drifting hooligans.
I don't see the M2 , M3 and M4 receiving xDrive. That is a whole different philosophy and it contrasts with the new direction on lightweight application.
The M5 G80? Well there is two garages one contains the new M5 embodying a new lightweight philosophy with Carbon load bearing structure and body panels.
The other garage has the same car but features the xDrive system and is slightly heavier... It all comes down to choice... Lightweight RWD or XDrive?
You cannot have both... And that will be the choice...RWD or XDrive. And possibly no manual.
It was interesting at Beijing to sit in a customer Q&A with BMW M. And the Chinese requesting the next M5 to be more harder than the current car in both character and design.
The M850i is evidence that BMW have got their mojo back when it comes to dynamic sports cars...
      05-01-2014, 02:11 PM   #306
dmboone25
dmboone25's Avatar
4972
Drives: 2024 Golf R / 2022 718 Spyder
2007 E92 328i  [10.00]
2007 328i  [10.00]
This is along that lines of what a few of us were guessing a few pages back - Xdrive in the bigger M cars and not available in the smaller ones...makes sense to me, especially if BMW's focus is going to be on weight reduction moving forward.
You can have a helleva car with ~400BHP if it weighs less than previous models...imagine the E92 M3 with the same type BHP numbers, but 3 or 400 pounds lighter...who cares about AWD in such a scenario???
Past rides: 2016 981 BGTS, 2020 MINI JCW, 2017 F80, 2015 981 CS, 2014 F22 235, 2011 E82 135, 2008 E82 135, 2007 E92 328, 2007 E92 328 (My lady drives an OG M2. So does my dad)
      05-01-2014, 02:12 PM   #307
bluekn8286
Drives: 2011 E92 BMW M3 Dinan S1
I will find a way to buy this no matter what!
      05-01-2014, 02:14 PM   #308
BMWJS
BMWJS's Avatar
Drives: 2017 GT350
Many great comments. Best news to me is the upgraded N55 6 cylinder and targeted hp. Looking forward to reduced weight, the wide arches, etc!
Tags
2015 bmw m2, 2015 m2, 2016 bmw m2, 2016 m2, bmw f22 m2, bmw f87 m2, bmw m2, bmw m2 coupe, bmw m2 coupe news, bmw m2 engine, bmw m2 f22, bmw m2 f87, bmw m2 forum, bmw m2 forums, bmw m2 motor, bmw m2 n55, bmw m2 n55 engine, bmw m2 news, bmw m2 render, bmw m2 rendering, bmw m2 renders, bmw m2 rumors, f22 m2, f87 m2, m2 coupe, m2 f87, m2 forum, m2 forums, m2 n55, m2 news, m2 rumors, n55 bmw m2, n55 m2
m2
