F22 Wheel Fitment |
View Poll Results: Will it work? | |||
Yes | 1 | 33.33% | |
No | 2 | 66.67% | |
Voters: 3. You may not vote on this poll |
02-29-2024, 07:01 PM | #1 |
Rep 6
F22 Wheel Fitment
F22 Wheel Fitment
Hello I have a 2018 f22 m240i rwd. Wondering if this set up would work. Slight staggered 18x8.5 front 235 40 et 35 / 18x9.5 255 35 et 40 rear. Thinking I may have to roll fenders. Please help so I can order the right rim/tire. I want to run Michelin pss and the wheels I want (3sdm 0.06) only come in at 35 or 40. Thinking maybe I should just run a square with 8.5s but i really want that 9.5 in the back. Can I make this work? First post forgive me Currently on snow tires 17x7.5 225/50 r17 et32. Car came with 19s with 225 35s and 245 30s that go flat when you hit a pebble. |
03-01-2024, 07:59 AM | #2 |
Rep 115
I believe the rear will be 100% fine. The fronts are what will be close or rub. Some 235s are fine with that offset. Some are not.
2014 228i M-Sport 6MT
"And the Porsche is still behind us..." |
03-01-2024, 11:07 AM | #3 |
Southern Fried
139
Rep 140
The rears are going to poke a good bit. Fronts are a toss up on rubbing.
03-01-2024, 02:11 PM | #4 |
Rep 1,022
It will be close in both cases, I would not bet either way, but so long as you know you may indeed need to roll the fenders at least you won't be surprised. ET40 would be safer in the front.
03-05-2024, 08:52 PM | #5 |
Rep 5,943
Not with 235 and 255. 225 and 245 may work but will require a decent amount of negative camber front and rear. For 235/255, you’d want 8et40 and 9.5et50-58
