09-18-2017, 02:32 PM | #2 |
Rep 906
Drives: 2008 535xi / 2011 Z4 35Is
09-18-2017, 09:17 PM | #3 |
Rep 414
I tried digging couldn't find anything myself. However look like it will transfer to the other side with ease though accompanied with a bracket.
10-27-2017, 05:10 PM | #5 |
114
Rep 59
All done...... There are three brakets that are used here. Two on the top as you can see and another on the bottom using the original grommet from the other side.
Everything will be all black. The red bushing are used to also help level coolant tank. It will be all refined when the plumbing is done. Still waiting on a part from Germany to come in to install. All BMW OEM plumbing pieces are being used. If anyone is interested in the relocation kit LMK. You get to keep the original coolant tank Last edited by BQ Tuning; 10-27-2017 at 05:45 PM.. |
Erez1610.00 |
11-02-2017, 09:11 PM | #7 |
114
Rep 59
Opens up space on the passenger side for upgtades, like single turbos, inlet upgrades like i did . The coolant being on the driver is the cold side of the engine bay. BMW also has the coolant tank on the driver side in their other model cars with the N54
Tangent303.00 |
11-06-2017, 07:45 AM | #8 |
Rep 370
I'm interested in that 90 degree fitting for the overflow hose. Did you source that and have a part number? Mine is straight and I could sure use a 90 degree one like that.
2009 Z4 35i 6mt, SpeedTech 6266 Gen2 turbo kit, Tial WG, VRSF 7.5 race IC, ER charge pipe, Tial BOV, Radium Fuel cell w/ surge tank and twin Walbro 525 pumps, Radium FPR and return line, Bluetooth ethanol sensor, Phoenix intake manifold w/PI, JB4 tuner, PR coil packs, Custom oil cooler, ECS Radiator, Spec 3+clutch, Mfactory flywheel, single 3.5" into dual 3" exhaust, H&R springs, 19" TSW wheels, 235/19 & 275/19 RE11 tires
11-06-2017, 11:29 PM | #9 | |
114
Rep 59
The X6 is longer which can always be shorten Another part of interest is the heater exchange return connector that T's into the main heater hose return line for the coolant tank to connect to instead of routing the line from the other side. Part # 11537805359 It replaces the following connector circled in red |
11-07-2017, 04:27 PM | #10 | |
Rep 370
BQ Tuning113.50 |
11-16-2023, 08:43 AM | #11 |
Rep 1
Drives: BMW Z4 SDrive35i
I’m interested in the brackets, I also emailed you. Thanks in advance! |
