01-23-2016, 07:32 PM | #1 |
Rep 886
Bimmertech Amp Installation DIY
Did the installation of the BimmerTech PP82DSP amp this morning. I thought it might be useful to post how it went, along with some comments.
Tools required: 10mm socket with 3" extensionRecommended Software:
The amp arrived via USPS 2-day Priority Mail, which took 3 days to get to my office after it was sent (Ben Franklin frowns). The outer box looked as through it had been stepped on. Inside, a smaller box was sliding around merrily, having been held in place with too little packing. The inner box was a white package with a seal and "F22" on the end (yay!). A slot had been cut in the box to allow part of the mounting frame to poke through. My guess is that the white box is the one that Bimmertech receives all their units in, and is sized for the F30 unit which doesn't need a specialty mount. So, what's in the box? The contents are below. The amp, mounted to the installation frame, a harness to connect to the car, and a 5' USB cable. The mounting frame is really nice, well made with an even crinkle finish. Now, that's it. The amp with frame and harness attached and a loose USB cable. Nothing else. NADA. No installation instructions. Not even a piece of paper directing me to some website for more info. Bupkis. Hey, no problem. Installation must be intuitively obvious. Well, we'll see. First, I turned DIP switches 2 and 4 on. Not because it's intuitively obvious, but because I'd seen one of the Bimmertech folks mention it online in another thread. Really? I'd suggest a note to tell people how to set the DIP switches. Next, I replaced the 5' cable with a 6' one that had a 90 degree connector added to the end (the vendor has noted they plan to add a 90 degree connector in the future). The cable I used also has a ferrite choke on the end, because who needs stray signals floating around in there (and because that was the only 6' cable I had lying around)? A bit of tape* secured the adapter to the cable, and then another bit of tape secured them both to the USB connection in the amp. Last thing you want is for the connector to fall out at some time in the future, requiring you to take your trunk apart again to plug it back in. * I used Zip System flashing tape, AKA The Tape From Hell. Don't let it touch anything you don't want it to try to grab onto and hold as though its life depended on it. My car is a 2015 M235xi with the harmon kardon audio package. ASD was disabled using a TechnicPNP ASD removal harness. That installation was described here (http://www.2addicts.com/forums/showthread.php?t=1202389), and I'm cribbing mercilessly from the trunk disassembly instructions I posted for that. NOTE: YOU NEED TO DISABLE ASD, EITHER THROUGH THE HARNESS I USED OR BY CODING IT OUT. It will be very obtrusive if you do not. If you love that ASD sound, this is not the amp you're looking for. You can check with the vendor to see if they offer the ASD removal cable when you purchase the amp, as there was some discussion of that becoming an option. Before you do anything else, turn down all the volume controls in the car. The radio, navigation voice, gong, parking monitors, phone, all of them. Last thing you want is something to start SHOUTING at you the first time you turn it on. The amplifier and ASD module are in the left side of the trunk, behind the liner. There are connectors in the trunk holding the inner liner to the body, one on a hook, one a straight pin connector, and one under the floor tiedown. Biggest nuisance is removing the floor loop. The plastic cover is easily popped off, revealing a large Torx bolt underneath. Naturally, this is in an odd size that doesn't match any of my Torx keys. Fortunately, it is easily grabbed with a small ViceGrip, and once it's loosened a 1/4 turn, can be easily removed by hand. The pin and hook connectors are easily removed by pulling the center section out and then removing the entire connector from the liner. Take care to not break the tabs and the connector can be reused at assembly. One more pin connector remains, hidden behind the folding seat. Drop the driver's side rear seat to expose the connector, and remove it in the same manner as the others. The back edge of the trunk at the latch now needs to be removed. Remove the four pin connectors from the cover plate, pull the trunk edge seal free, and remove the back plate. Once the trunk edge plate has been removed and the trunk lip seal has been removed just past the edge of the trunk liner, the trunk liner can be moved away from the body of the car. Move it about 6" away from the body, reach behind, and unplug the back connector on the trunk power socket. Then move the liner out of the way. The amplifier and ASD module are under the plastic liner support. Lift the liner support out of the way, allowing access to the electronics. The amp is the larger of the two under the tray, with the small vertical unit being the ASD module. My wiring looks slightly different from stock here due to the ASD removal harness, but it doesn't change the install at all. OK, let's see what we've got here. No obvious way to remove the old unit. Does the new one just sit on top? No, that doesn't look right. Well, let's start poking. Aha. There it is. A 10mm nut looks to be holding the tray down. Are there any others? I can't see any, but I can't see how everything goes in. OK, jam the camera in and start taking pictures to see what else is hiding in there. OK. it looks like there's the one nut and then two slide posts holding everything down. Let's pull that nut and see what happens. Pop the 10mm socket on the handle, slide it over the nut and .............. I've only got about an inch to work the socket back and forth. OK, grab an extender. And that when I find out I don't have an extender for my 1/8" socket. Really? For the love of .... Ah, screw it. Spend 5 minutes working the ratchet head back and forth one click at a time. Finally, get the nut off. OK, lets see what happens. Give it a tug. Hmmmmm. Nothing. Well, it's a German car, maybe the only thing it understands is force. Grab the far side of the amp and give it a TUG. And it slips out of the slide post and mashes my little finger between a couple of hard pointy things. Mother... OK, in any event, it's loose. The whole shooting match pops out of the little well and can be moved out where you can see what's happening. Turning it around reveals an 8mm hex head (sure, why use the same size?) that's holding the OEM amp in place. Pop it off and the amp slides right off the mounting tray. Press the retainer tab on the harness lock, slide the clip down, and the harness pops right out of the back of the amp. OK, let's pop that new amp in with the screw tab in the right place and ..... Uh, wait a minute. If I put this on the way the amp is on the tray and then put it into the little well in the car, all of the things I might want to get access to (DIP switches, micro SD card slot, USB connector) are going to be on the far side of the amp, hard up about a half inch off the wall of the fender. That's not good. This is not the way I'd have put it on the mount. But, that can be fixed. OK, into the house to turn it around, because it's 30 degrees out here (that's -1 to you poor folk stuck with SI units). The tray is held on with 4 small allen head screws. Grab a small allen key, sit down on the couch, start turning, and after about 15 turns ..... a little nut falls out of the amp, bounces off the hardwood floor, and flips under the couch. You miserable son of a ....... Has no one heard of self-tapping screws or retained nuts? Apparently not. Anyway, crawl around on floor feeling around under couch, and finally come up with it after first getting a whole bunch of dust bunnies ("Well, the vacuum cleaner head doesn't fit under there." - The Wife). Go over to the kitchen table and take the rest of the screws out in the box. OK, putting it back together is a real pain. The little free bolts need to be held in with a needle nose plier while you try to arrange a screw - tray - washer - amp sandwich with the other hand. Harder than it sounds, and I kept doing screw - washer - tray instead of screw - tray - washer. Eventually got it done, but it took around a half hour. Via a response in this thread below, the manufacturer should be mounting this way in the future, but you should check before you go out the car in the first place. EDIT: It looks like the manufacturer does read the forum, and is planning on shipping the mounts in the above configuration. Check that yours in the in the right position out of prudence, but kudos to BimmerTech. Now, let's plug the two white cable connectors on the harness into the two white sockets on the amp. Not because anyone told us to, but because that seems to be the thing to do here. Again, a single sheet of paper telling this stuff to the person installing the amp would be nice. Looks like the amp is being attacked by an octopus here. OK, now take the amp back to the car. Drop the bottom of the mounting tray into the slots on the mounting frame from the car, slide the tab up aginst the screw hole, and run the hex head in. The amp is now on the mounting frame for the car. Finally, plug the harness from the car into the socket on the cable that came with the amp (it only goes one way), slide the clip up over the latch pin, and all the wiring should be done. Before everything gets put back in, let's turn on the car and see if there's sound. Hey! It makes noise! OK, let's get to reassembling stuff. Drop the tray down into the well. Put it all the way towards the front of the car, then slide it towards the rear, lifting the hole in the tray where the nut will go over the pin that the nut screws onto. Make sure the slide pins are in their little grooves, and slide it towards the back of the car until it stops. Great! Lets just put that little nut back on. Finger tighten the nut over the screw post (Hey, I didn't drop it!) until it hits the plastic insert that keeps it tight. Pull out the 10mm socket and tighten it up. Ah, dammit! With all the extra wires, I can't get enough swing on the handle to click the ratchet. This isn't going to work without an extender. And as I found out earlier, I don't have one. Fortunately, my wife's car is behind mine in the driveway. A quick run to Home Depot provides the extender, and the nut runs right down on the post. The thing to do now is to test the software connection to my laptop. "Wait a second", you say. "It didn't say nothing about software on the box. Or in the box. Or on the amp. How did you know about this software?" Oh, I saw that in another post on some forum online. And you've seen it in this post. What more can you ask for? Anyway, pull out the laptop on which I've installed the software, and plug the USB cable in and ... watch it fail to find a driver. Uh, that's not good. Maybe this doesn't need a driver? Fire up the software and .... no connection found. Oh for the love of .... I've got to play Windows driver debug? Well, OK, uh .... Ah, hell. It's starting to snow. And I'm in the driveway with the back end of my car disassembled. Driver games will have to wait, I need to get this thing closed up. At least the laptop sees the amp, so I know I've got a functional cable connection. Before closing up, make sure you leave the USB cable end in the battery compartment so you can get at it. Then, use a small zip tie or two to secure the harnesses to the frame of the car so that they don't shake back and forth to create a rattle behind the lining of your trunk. That seems to be it. Reassemble the trunk liner in the reverse order that you took it apart.
Got everything buttoned up, and rolled into the house. Started digging around on the computer. Apparently, the software installation program put a USB driver program in the Program Files directory of the software itself, but didn't bother to run it. Nah, why would you expect the install program to install everything it needs? So, run it by double clicking on the file name, reboot the computer, and go back out to the car. Plug it in again, watch the USB drivers install, start the software, and ... hey, it's up! Success! EDIT: The paragraph immediately above was with Version 2 of the software. A later version is linked at the top of the post above, and THAT one did install the drivers. And it's snowing and it's cold. I'll deal with tuning later. Poking around online shows a bunch of people saying they have the "custom" file for the F22, but all of the files posted seem to start with "F30". Well, we'll see what a bit more digging (and perhaps emailing) turns up. EDIT: About a month after my initial install, BimmerTech released tuning files for F22 cars with either the HiFi or harmon kardon systems. Those files are now up at the top of this post. As stated both above and below, the only change I made to this is disabling the Power Save mode as noted in the edit immediately below. EDIT: One thing that popped up in the first week of use is that the "Power Saver" function on the amp disables both the phone and navigation speakers if the radio is "off" for more than 60 seconds. As such, I would highly recommend that the "Power Save" be disabled. To do this, use the following steps:
Total time was around two hours, including a half hour or so to turn the mount around on the amp and perhaps 25 minutes to go to Home Depot to get a 3" extension for my small socket. This doesn't include poking around trying to figure out why the computer wouldn't connect. Not a bad install. Not everything is obvious, however. Desperately needs more instructions if you haven't been lucky enough to trip over the right threads online. Then again, anyone reading this already has. FWIW, George
Prior 40 years: 67 BelAir wagon / 68 LeMans Tempest / 70 Mustang Mach 1 / 72 El Dorado / 78 Corvette / 81 Subaru GL wagon 4WD / 83 s10 Blazer 4x4 / 85 Bronco 4x4 / 96 Bronco 4x4 / 04 Passat 4mo / 09 BMW 335xi Last edited by Zooks527; 06-18-2017 at 03:21 PM.. |
01-24-2016, 09:35 AM | #2 |
Rep 130
Drives: 2015 M235i xDrive
Great write-up! Thanks for spending the time to go through step-by-step on the install. Mine hasn't shipped yet but hopefully soon.
Do you have any initial impressions with the sound quality?
Current: 2015 M235i F22 BSM (FBO)
Current: 2015 X5 M Sport CBM (hers) Previous: 2008 335i E90 Tiag (FBO) |
01-24-2016, 12:50 PM | #3 |
Rep 832
Thanks for the installation instructions write up and feedback. We don't have access to a 2 series so i appreciate all the feedback you gave us in this thread. Although no instructions were sent i did post a link to both the amp manual and software in the group buy thread which you were a part of.
01-24-2016, 02:45 PM | #4 | |
Rep 886
Much improved stereo fidelity. The door tweeters are now actually participating in the "soundstage" reproduction in the car. Granted, it's still obvious I'm listening in a car, but I'm getting much better separation that I had before. Strikes me as a bit too high on treble and appears to be too forward focused for my liking, but (a) that's adjustable and (b) it's a significant improvement over stock. No regrets on the purchase.
Prior 40 years: 67 BelAir wagon / 68 LeMans Tempest / 70 Mustang Mach 1 / 72 El Dorado / 78 Corvette / 81 Subaru GL wagon 4WD / 83 s10 Blazer 4x4 / 85 Bronco 4x4 / 96 Bronco 4x4 / 04 Passat 4mo / 09 BMW 335xi Last edited by Zooks527; 01-24-2016 at 03:02 PM.. |
01-24-2016, 02:49 PM | #5 | |
Rep 886
The manual has its good and bad parts. One thing to be aware of is that it makes a big deal of wiring directly to the battery and not using the harness for power, which is clearly not the case with the custom harness you provided. You obviously spent a good deal of time getting the harness right, and you should take credit for it. The custom mount is quite nicely made. I do think you should turn it 180 degrees from the orientation in which I received mine. Since you're looking at the thread, I do have a question. The tuning file I have is titled "F30 HiFi Bimmertech audio tuning file.afp". Is that the right one to be using for an F22, or is there a better one to use?
Prior 40 years: 67 BelAir wagon / 68 LeMans Tempest / 70 Mustang Mach 1 / 72 El Dorado / 78 Corvette / 81 Subaru GL wagon 4WD / 83 s10 Blazer 4x4 / 85 Bronco 4x4 / 96 Bronco 4x4 / 04 Passat 4mo / 09 BMW 335xi Last edited by Zooks527; 01-25-2016 at 08:30 AM.. |
01-24-2016, 10:27 PM | #6 | |
Rep 224
I have been asking this question several times ..in F30 forum and I was told it comes with F22 base tune file .. after reading this looks like this is DEFINITELY not the case. Now this is starting to feel like $700+ mistake.
01-25-2016, 04:30 AM | #7 | |
Rep 886
The sound in the car is much improved, and the software mentioned in the F30 forum will allow me to move things the way I want them. However, if there is a specific F22 file out there that I don't have, that would surely be a decent place to start. EDIT: OK, had a half hour in the car today on the way to work, this time without my wife, which lets me run the volume around. The system is greatly improved and I was able to get the perceived location of the instruments and voices pretty much where I wanted them using just the 4 basic (Treble/Bass/Bal/Fade) controls in the car. I'm still going to want to tweak it with the software, but it's really good at the moment. But, the new system really shows up the limitations of the input material. Running from a CD (The Who's Tommy), it sounded really great. Really, really great. However, switching to the in-car hard drive, with MP3s of various provenance and varying bit rates, you can hear every compression artifact. That's not a knock on the amp, which is reproducing what it's being fed faithfully and clearly, it's a note that if your music collection is composed of low bitrate rips from YouTube music videos, you're going to be hideously disappointed. I expect that for MP3 files I'll be using thumbdrives through the USB port (where I can keep the bitrate up) instead of the car's hard drive, which apparently downsamples higher rate material to 256 kbps.
Prior 40 years: 67 BelAir wagon / 68 LeMans Tempest / 70 Mustang Mach 1 / 72 El Dorado / 78 Corvette / 81 Subaru GL wagon 4WD / 83 s10 Blazer 4x4 / 85 Bronco 4x4 / 96 Bronco 4x4 / 04 Passat 4mo / 09 BMW 335xi Last edited by Zooks527; 01-25-2016 at 08:29 AM.. |
01-25-2016, 03:04 PM | #8 |
Rep 2,942
Glad to hear the amp is a significant upgrade, and that mayyyybe it partially solves the horrendous CD output quality issue. As I've written in other threads (and have had somewhat borne out via A/B listening with lossless 1411/96 AIFF files via an iPhone hooked up with the analog aux input), I strongly suspected that the CD player downsamples for playback as well as ripping to the on-board HDD. Maybe that's not the case, then ...
... and if it isn't, it's direct evidence that the OEM DSP curve is really, really crappy. Kudos for the writeup. Let's all hope the company actually hires a technical writer and starts including something like it in the package.
01-25-2016, 03:46 PM | #9 | |
Rep 886
I fired up the radio in the car with the engine off. With both sources set to the same place in the song, I can toggle back and forth between the .WAV and the CD itself. If there's a difference between the two, I can't hear it. I'm willing to try some other comparison if you think there's a better test. At home, I can get a patch cable from the Box-O'-Cables and run the .WAV in through the AUX input from my phone to avoid any question of it downsampling what it pulls from the USB and the CD in the same manner. There is the whole digital - analog - digital swing there, though. FWIW, George
Prior 40 years: 67 BelAir wagon / 68 LeMans Tempest / 70 Mustang Mach 1 / 72 El Dorado / 78 Corvette / 81 Subaru GL wagon 4WD / 83 s10 Blazer 4x4 / 85 Bronco 4x4 / 96 Bronco 4x4 / 04 Passat 4mo / 09 BMW 335xi Last edited by Zooks527; 01-25-2016 at 03:54 PM.. |
01-25-2016, 04:04 PM | #10 | |
Rep 2,942
The comparison really needs to be between the digital input (or, in the case of the CD player, the output) and the analog input, the latter of which bypasses any possible digital-to-analog conversion by the HU. Based on what I heard this past weekend (and was gonna post about), I heard some differences between the CD player output and my AIFF files fed through the analog input, but not tremendous differences -- which leads me to suspect that the difference in tonalities are primarily DSP-based and not completely downsampling-based (but it could be jitter-based; depends on the sampling rate of the CD player). I played with some of iTunes' EQ settings and noted that the ones with bumps in the low and high bands (Jazz, Rock, Latin, etc.) helped even out the sound spectrum at given volumes, which is definite evidence that there is an immense mids-hump in the OEM DSP (we in the bass-playing word call it an EQ "hump"; the opposite is called a "scoop").
01-25-2016, 04:13 PM | #11 | |
Rep 886
Ah, what the hell, I'll dig up the stuff tonight to run my phone through the AUX port using the WAV file, and compare it to the CD. Likely won't be able to actually try it until tomorrow morning, but I'll see what I can get. EDIT: Hah! Had a patch cable in the Drawer-O'-Cables here at work. Just went out and alternated between the CD and the .WAV run through the AUX In from my phone. Some slight issues with trying to get the volume matched, but again, I really can't hear any difference. I'll guarantee I couldn't hear one if the engine were running. I'll caveat this with the observation that people who bought the album I'm playing around the time they entered their teens may not have the best frequency response remaining in their ears, although testing a few years back showed my hearing then was better than the average person in his 30s.
Prior 40 years: 67 BelAir wagon / 68 LeMans Tempest / 70 Mustang Mach 1 / 72 El Dorado / 78 Corvette / 81 Subaru GL wagon 4WD / 83 s10 Blazer 4x4 / 85 Bronco 4x4 / 96 Bronco 4x4 / 04 Passat 4mo / 09 BMW 335xi Last edited by Zooks527; 01-25-2016 at 04:31 PM.. |
01-25-2016, 05:13 PM | #12 | |
Rep 2,942
(Actually, I was smart; was an early adopter of the frequency-balanced custom-moulded earplug. I credit 'em with saving my hearing at my present age.) Good enough for me ... and yep: good enough for the car environment. Glad to read that most of the CD player's issues are directly tied to the HU's sonic biases.
01-25-2016, 07:57 PM | #13 | |
Rep 886
I should note that when my hearing was evaluated as "better than the average person in his 30s", I was entering my 50s. One of my wife's best friends worked for David Clark back in the day and was able to get me the good stuff. Still, time does knock some of the response down.
01-30-2016, 12:30 PM | #14 |
Rep 886
I emailed BimmerTech and they sent me a tuning file for the F22. I installed it today (1/20/16 - a week after initial amp install) and I'll see how I like it. I've attached a copy of the file at the end of the first post in this thread. The only change I made to this is disabling the Power Save mode as noted in the edit I made in the first post above. The files is named "F22 HIFI (1) no PSM.afp.pdf" as I don't know another way to attach it. Download the file and then rename it by removing the '.pdf' from the file name. It can then be uploaded to the amp.
01-30-2016, 01:45 PM | #15 |
Rep 11
I've read a couple places that the amp isn't compatible with HK systems.
Then I've also read a couple places that the amp IS compatible, but you should code your car to "HIFI" instead of HK. I'm asking because I JUST picked up my car, and the dealer thought they were doing me a favor and upgraded me to HK when I assumed I was getting Hifi. BOOOOO. Then I read your thread saying it's compatible. Which is it?!? |
01-30-2016, 02:42 PM | #16 | |
Rep 886
It's not compatible with the hk systems in all series above the 2-series. Those are the cars with on-board equalizers and other goodies. However, in the 2-series, the hk system simply adds better subs, a stronger amp, and 5 extra tweeters (1 each at all speaker locations excluding the subs) tied to the same channels as the base speakers. There's minimal controls for the radio (B/T/Bal/F), no equalizer, and so on. As such, it's the same as a HiFi system from the perspective of the BimmerTech amp. They ask for your VIN when you order it, so there may be a difference in the harness they provide to you. However, in the 2-series, once you have it in hand there's no issue with hk vs. HiFi and no coding for radio type needed. You do need to get rid of ASD, either by a harness or by coding, but that's it.
Prior 40 years: 67 BelAir wagon / 68 LeMans Tempest / 70 Mustang Mach 1 / 72 El Dorado / 78 Corvette / 81 Subaru GL wagon 4WD / 83 s10 Blazer 4x4 / 85 Bronco 4x4 / 96 Bronco 4x4 / 04 Passat 4mo / 09 BMW 335xi Last edited by Zooks527; 02-01-2016 at 08:04 AM.. |
01-30-2016, 03:16 PM | #17 | |
Rep 11
I'm hoping that coding the system back to Hifi will get rid of the on-board EQ and "goodies", if not, I'll have a cheap bimmertech amp for sale. |
01-30-2016, 04:04 PM | #18 |
Rep 146
Do you know if the tuning file that they sent you is different from the F30 one they had been providing previously?
2015 ///M235iX | Mineral Grey | Dakota Black | Premium | Tech | Cold | Driver Ast | HK Sound | Black Kidney Grilles | M-Performance Exhaust | Front Splitter | Carbon Fiber Mirror Caps, Rear Spoiler and Exhaust Finishers
01-30-2016, 04:11 PM | #19 |
Rep 886
Hang on until tomorrow morning. I'll load the two of them side-by-side on my laptop and compare the curves.
01-30-2016, 04:18 PM | #20 | |
Rep 886
The files are completely different. The frequency curves are not the same, and the time / phase / distance settings are very different, with the distances in the F22 file being much shorter than those in the F30 file.
Prior 40 years: 67 BelAir wagon / 68 LeMans Tempest / 70 Mustang Mach 1 / 72 El Dorado / 78 Corvette / 81 Subaru GL wagon 4WD / 83 s10 Blazer 4x4 / 85 Bronco 4x4 / 96 Bronco 4x4 / 04 Passat 4mo / 09 BMW 335xi Last edited by Zooks527; 02-01-2016 at 07:38 AM.. |
02-01-2016, 06:55 AM | #21 |
Rep 146
Thanks! I'll have to try that tune out.
02-01-2016, 07:40 AM | #22 |
Rep 886
I loaded it over the weekend. Waaaaaay too bright, likely because it's targeted for the HiFi system and I have the hk speaker set (5 more tweeters). I'm going to try toning it down this week.
Prior 40 years: 67 BelAir wagon / 68 LeMans Tempest / 70 Mustang Mach 1 / 72 El Dorado / 78 Corvette / 81 Subaru GL wagon 4WD / 83 s10 Blazer 4x4 / 85 Bronco 4x4 / 96 Bronco 4x4 / 04 Passat 4mo / 09 BMW 335xi Last edited by Zooks527; 02-01-2016 at 08:05 AM.. |
