10-21-2019, 10:08 AM | #23 |
Rep 111
All US models will have the 8S4 "Decoding Variable Light Distribution". That means it is turned off for the US market. It can be coded (turned back on) via Bimmercode. Supposed to not be permanent if the dealer does any software updates but I made it through an update with VLD still enabled. I have not checked in code but when you start the car if your headlights sweep out, in and level then it is working.
BM235iW97.00 |
10-21-2019, 07:37 PM | #24 |
Rep 121
Yes, by default, though you could remap to other lamps.
Zyzzthetic146.50 |
10-21-2019, 08:08 PM | #25 |
Rep 230
Drives: 2018 240i
Digital speed
I really only have done the digital speed in info on dash.
Is there a one push engine shut off ? Will monitor this thread for anything else that looks interesting. Hap |
235Paul3.00 |
10-21-2019, 08:17 PM | #26 |
Rep 157
Zyzzthetic146.50 |
10-22-2019, 01:06 AM | #27 |
The Bandleader
29
Rep 29
Hi! New to the forum here but been a big fan and looking around for years. You all have helped immensely with your Q&A's the last couple years on my decision in getting my 2019 M240i last January! Coming from a 1998 Z3 2.8 that i had 225,000 miles on, holy CRAP the M240i has been INSANE!
Anyway, to DriftCarHero, how were you able to get the variable light distribution and anti dazzle enabled using Bimmercode? I have not coded anything yet but didn't think it was possible using Bimmercode, just the angel eyes brighter. Help is appreciated. Thanks! |
10-22-2019, 08:58 AM | #28 | |
388
Rep 889
Can anyone confirm or deny this? |
10-22-2019, 10:14 AM | #29 |
Rep 111
For any coding out of the norm I recommend Pikachu's coding cheat sheet.
https://www.2addicts.com/forums/showthread.php?t=997749 For VLD and Anti-Dazzle you need to go into Expert Mode on the Front Electronic Module. Module 3073 Options C_AFS_ENA LUT_FLC_FORWARDLIGHTING_Y C_HBA_ENA C_HBA_GRHB_ENA C_HBA_ADAPT_SHUT_ENA I am not sure about different hardware. I didn't think there was when I first looked into this. |
Kokanator13522.00 |
10-22-2019, 10:24 AM | #30 | |
Rep 146
https://www.amazon.com/Vgate-Elm327-.../dp/B01FU5MVI8 I haven't changed much, disabling ASD was the first but with a convertible, and driving top-down 85% of the time it did not matter to me when it was re-enable during the last software update.
2018 ///M240i Convertible [Loaded - Garage Queen]
2018 Ford F150 XLT FX-4 [Daily Driver] BMW CCA #535395 SCCA #619713 |
zentanker205.00 |
10-22-2019, 10:32 AM | #31 | |
The Bandleader
29
Rep 29
10-22-2019, 11:45 AM | #32 | |
Rep 157
10-23-2019, 12:03 AM | #33 | |
Luxury at the redline :)
9108
Rep 7,563
With the Xenon headlights for the F22, there is no hardware difference, like some claim; the technology is very rudimentary in its operation, as it's just a low/high-beam shutter and the projector ball on a swivel motor, in both the US-spec and Euro headlights. So if your vehicle already has the High-Beam Assistance option, there is no reason if you code in the European operation of VLD & GFHB, which would operate properly on the US-spec vehicles, since they share the same setup. Xenon folks just lucked out in the US but you also need High Beam Assistance option (5AC) for it to work properly. With the LCI LEDs, however, it operates different than Xenons hi/low shutter and instead utilizes an array of LEDs and reflection to create the light outputs. So I'm not 100% sure if VLD or GFHB in the US-spec vehicles have proper arrangement of lights to properly form a glare free high beam. BMW is know to skimp to LEDs highlight array when it's not needed, as with some US-spec vehicles, in an attempt to reduce cost and heat. So I can't confirm if they differ until some cracks open a F22 LED headlight, from both region and compare and contrast. Also, the coding is different for the LCI LED headlights than for the Xenons, which is listed above. |
10-23-2019, 08:14 AM | #34 | ||
Rep 1,268
10-23-2019, 10:51 AM | #35 |
Rep 111
That is what I did. I don't if know if it is right or not. There is so much back and forth debate on this topic. I am happy with headlights. Have not been flashed on the highway, had a truck pull over that I was following on a 2 lane road. I try to use the high beam assist respectfully. Your mileage may vary so see how people react and adjust accordingly.
10-23-2019, 07:44 PM | #36 | |||
9108
Rep 7,563
The LCI LED coding is way more intricate. |
10-23-2019, 08:02 PM | #37 | ||||
Rep 1,268
10-23-2019, 08:19 PM | #38 |
Rep 42
10-23-2019, 08:29 PM | #39 | |||||
9108
Rep 7,563
Keep in mind, no one has yet confirm that the LED array in the US-spec headlights are the same as the Euro-spec. So there is a possible it would not work as it suppose to if it doesn't have the correct hardware. https://www.bimmerpost.com/forums/sh...php?p=24640779 https://f80.bimmerpost.com/forums/sh....php?t=1151903 It's not something you can code with BimmerCode. |
10-23-2019, 09:40 PM | #40 | |
6 speeeeeeeeeed
147
Rep 214
Vgate Wifi iCar2 as thats the one the bimmercode app supports.
17' 240i 6MT - black on red
10-23-2019, 09:43 PM | #41 | |
6 speeeeeeeeeed
147
Rep 214
10-24-2019, 10:05 AM | #42 |
Rep 111
That sucks about coding the LCI adaptive LED headlights. I need to get back into BimmerCode and figure out what I did wrong. Maybe I will stick to VLD unless I want to pay a professional coder.
10-24-2019, 11:52 AM | #43 | |
Rep 157
My guy, thanks! |
Zyzzthetic146.50 |
11-08-2019, 07:47 PM | #44 |
Rep 449
Tire pressure/temp
My car is a very early 2014 model, and the tire screen only showed 'green' tires if the pressure was good. So my favorite Bimmercode option was turning on both tire pressure and tire temperature display. It is SO useful at the track, and great way to check pressures anytime.
The 5 blink option is my second favorite. Other than that, I mainly just swapped some logos so I wouldn't have see M235 everywhere, and disabled the iDrive warning. |
