08-02-2014, 09:07 PM | #23 |
Rep 855
08-03-2014, 09:13 PM | #24 | |
Old Guy
25
Rep 89
Drives: 2018 M2 LCI, 2019 X3
08-03-2014, 09:17 PM | #25 |
Rep 418
This is an awful lot of guess work by a lot of people. I wish BMW would definitvely state *exactly* what happens. They don't, so here's my best guess based on testing today and from other posts.
Eco Pro Slowest driving behavior, loose throttle mapping, low shift points, allows car to coast when off the throttle and does some regenerative charging. Comfort Normal throttle mapping, higher shift points, no changes to chassis/steering from eco pro. Sport Follows the user-settable options for drivetrain/chassis. Tighter steering/throttle mapping and higher shift points than comfort mode. Shock dampening more aggressive. Sport+ Drivetrain, chassis, steering & throttle in the "sport" setting. These should be identical to "Sport" settings, if both chassis and drivetrain were selected in the "Sport" settings. The only change should be that DSC is turned to DTC. If you put the car in cruise control, it will automatically switch back to "Sport" mode. Auto Shifter When you tip the shift lever to the left, it seems to drop the A/T into a lower gear. Regardless of which mode you're in, it seems to do this. So today I was going about 30mph in comfort mode. Clicked into "Sport" mode and watched the rpms hop up a bit. Tipped the shifter to the left and they went up even higher (lower gear). In short, I believe the shifter is *independent* of the driving mode. Perhaps a gear drop won't happen if I were in Sports mode and already at high rpm, but at modest rpm, the shifter caused a downshift, regardless of mode. Love to be corrected if any of this is wrong... |
08-03-2014, 09:27 PM | #26 |
Rep 5,262
Shift lever to the left It will drop a gear right away and then go back up....no matter what driving mode you are in
if you are in 7th gear and you start doing left-right-left-right-left-right you would end up in 4th... |
08-03-2014, 10:21 PM | #27 |
Rep 862
Drives: '19 M2 '21 X5
I believe sport shift has more rapid shifting (the 200 ms shifts) as well as remapped shift points. I have also notice that it tried to hold the Rpms more when braking leading to a bit of droning during engine braking.
08-03-2014, 10:35 PM | #28 | |
Rep 418
OK, now I'm gonna try this…. |
08-03-2014, 10:42 PM | #29 | |
Rep 418
Good point. I think you're right about the quicker shifts. Not sure if it's a product of the mode or just that the shift is happening at a higher rpm, giving it a "Thunk-ier" shift. But it does feel like it shifts faster. You also make a good point re downshifts. The sport modes definitely hold onto their gears longer when braking before down shifting. I remember that month's ago several reviewers mentioned that when braking, the M235i was in the perfect gear for blasting out of corners, without having to manually downshift. I saw that today as I slowed as I approached a red light in Sport+. The light changed to green before I'd stopped and I was able to goose it and pull right away w/o any perceptible downshift. |
08-04-2014, 02:03 AM | #30 | |
Rep 862
08-04-2014, 11:33 PM | #31 | |
Rep 7,047
For my part I'm not guessing, I'm going from experience and reading tech info on how ZF designed this trans. It's a very high tech torque converter trans. The best AT I've ever driven, and I'm an MT driver who got caught up in the high tech-ness of it all. But I think my next BMW will be back to MT. Regarding the trans and shift lever position, we've covered what it does. What you are experiencing is how it is designed to work. In any driver mode, moving the lever to the left puts the trans in DS mode, which is sport mode for the trans shift programming, where it holds gear longer waiting to shift at higher rpm for better acceleration, because you're accelerating in the lower gear longer. Anytime you select DS by moving the lever over the trans will drop one gear, because it thinks you want faster/sportier acceleration. If you are in sport mode, with chassis+drivetrain selected, keeping the lever in the normal right side position also puts the trans in "sport" mode, meaning it will hold gear longer. Moving the DS mode will drop a gear, but will retain the sport shift programming. IOW, when in sport mode the trans shift program is the same whether the lever is in standard position or the the left/DS position. Even though it downshifts 1 gear it will still upshift fairly quickly to where it was and then continue to shift under the same programming. You can test that by keeping the throttle steady while in the standard lever position, then move it to the left/DS position, it'll downshift 1 gear but as lnog as you don't push the throttle for acceleration the trans will shift back up. It's an odd thing that BMW thought would be cool I guess. You can get the same effect by leaving the lever in default position and pressing on the throttle to activate a downshift like for passing. You may have discovered this already, if you press the throttle down it will down shift a gear. But if you push ALL the way down past that little resistance point, it will activate a multi gear downshift for RIGHT NOW passing. |
08-06-2014, 07:54 PM | #32 |
Rep 5,262
lol... just found this...
ICM 3000 IcmKod_B_InitEco verbaut nicht_verbaut The vehicle will start in drive mode Eco Pro every startup. I guess there is remember ECO PRO but not Sport |
